Industrial USB 2.0 Flash Module
Specification
(FxAlp Series, SLC)
Version 1.5
Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585
Tel : +65-6493 5035
Fax : +65-6493 5037
Website: http://www.flexxon.com
Email: flexxon@flexxon.com
ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED,
OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON.
TABLE OF CONTENTS
1.
2.
GENERAL DESCRIPTION ............................................................................. 1
1.1.
Introduction........................................................................................................................ 1
1.2.
Product Overview .............................................................................................................. 2
PRODUCT SPECIFICATIONS........................................................................ 3
2.1.
Performance ....................................................................................................................... 3
2.2.
Power ................................................................................................................................. 3
2.3.
MTBF ................................................................................................................................ 4
2.4.
Data Retention ................................................................................................................... 4
3.
ENVIRONMENTAL SPECIFICATIONS........................................................... 5
4.
PIN ASSIGNMENT ....................................................................................... 6
5.
PHYSICAL DIMENSION ............................................................................... 8
6.
ORDERING INFORMATION ......................................................................... 9
1. GENERAL DESCRIPTION
1.1. Introduction
FLEXXON’s Industrial USB Flash Module (FxAlp series) is fully compatible with USB specification
(USB1.1 / USB 2.0). It offers super performance & fast data transfer especially in 4K random write.
Moreover, it also offers wide compatibility and high reliability, suitable for different type of
applications and built-in systems in any rigorous environment.
1
1.2. Product Overview
Flash
SLC
Capacity
1GB up to 32GB
High IOPS
AES 128 & 256 bits encryption engine.
Conformal Coating (Anti-Dust & Anti-Moisture).
Compatible with USB specification revision 1.1 and 2.0.
Support Windows 2000 SP4 and Windows XP without device driver.
Support Windows Vista and Windows 7 without device driver.
Support MAC OS X and later without device driver (USB 1.1 speed).
Support MAC OS 10.2.8 and later without device driver (USB 2.0 speed).
Support Linux Kernel ver2.4.0 or above without device driver (USB 1.1
speed).
Support Linux Kernel ver2.4.10 or above without device driver (USB 2.0
speed).
ECC Scheme
BCH ECC Engine correct up to 96 bits error in 1K Byte Data
No external power is required—DC 4.5V-5.5V from USB port.
Transfer rate for USB interface:
High speed up to 480Mbits/sec for USB 2.0
Full speed up to 12Mbits/sec for USB 1.1
Low Power Consumption
Sudden Power Loss Management
Dynamic, Static & Global Wear Leveling Algorithm
Temperature Range
Operation: -40°C ~ 85°C
Storage: -40°C ~ 85°C
RoHS Compliant
2
2. PRODUCT SPECIFICATIONS
2.1. Performance
Table 2-1 Performance of FxAlp UFM
Sequential
Random
Max. Read
(MB/s)
Max. Write
(MB/s)
Max. Read
(IOPS)
Max. Write
(IOPS)
31
23
2000
1000
NOTES:
1.
The performance was measured using CrystalDiskMark.
2.
Performance may differ according to flash configuration and platform.
2.2. Power
Table 2-2 Supply Voltage of FxAlp UFM
Parameter
Rating
Operating Voltage
5V +/-5%
Table 2-3 Power Consumption of FxAlp UFM
Capacity
1GB ~ 32GB
Item
Power Consumption (mA)
Active
很抱歉,暂时无法提供与“FUUD008GSE-H600”相匹配的价格&库存,您可以联系我们找货
