FSSE120GBE-M500
FSSE120GBE-M500
    FLEXXON
    固态硬盘(SSD) FLASH - NAND(TLC) 120GB SATA III mSATA
FSSE120GBE-M500 数据手册
Industrial mSATA Specification (INSPIRE Series, 3D TLC) Version 1.3 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................. 1 1.1. Introduction........................................................................................................................ 1 1.2. Product Overview .............................................................................................................. 1 1.3. Power Loss Protection (Optional) ..................................................................................... 2 PRODUCT SPECIFICATIONS ........................................................................ 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. TBW (Terabytes Written) .................................................................................................. 4 2.4. MTBF ................................................................................................................................ 4 2.5. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS........................................................... 5 4. ATA COMMANDS .......................................................................................... 6 5. PIN ASSIGNMENT ....................................................................................... 8 6. PHYSICAL DIMENSION ............................................................................. 10 7. ORDERING INFORMATION ....................................................................... 11 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s INSPIRE mSATA has SATA III interface, and is fully compliant with mSATA Form Factor, known as JEDEC MO-300. It supports high performance, high endurance, good compatibility and provides comprehensive data protection. It is suitable for multi-tasking application. 1.2. Product Overview  Flash  3D TLC  Capacity  64GB up to 2TB  SATA Interface  Compliant with SATA Revision 3.2  Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface  ECC Scheme  INSPIRE mSATA applies the LDPC (Low Density Parity Check) of ECC algorithm  UART Function  GPIO  Support SMART and TRIM commands  Support DDR3/DDR3L External DRAM  Low Power Management  Power Failure Protection  Data shaping technique for enhanced data endurance  Data Refresh technology for data integrity  Global Wear Levelling Algorithm  AES256 and TCG OPAL (Optional)  Temperature Range  ■ Operation (Silver) : 0°C ~ 70°C ■ Operation (Diamond) : -40°C ~ 85°C ■ Storage: -55°C ~ 95°C RoHS Compliant 1 1.3. Power Loss Protection (Optional) FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity and prevent data loss. Normal operation Unexpected Power Loss happens When the SSD detects the host power The SSD is powered by the host power, and dropping, the power loss protection circuit the power loss protection circuit is charged starts to provide power to the SSD while it by the host power. flushes cached data from DRAM to NAND. Figure 1-power loss protection mechanism 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of INSPIRE mSATA Sequential Capacity Read (MB/s) Write (MB/s) 60/64GB 392 245 120/128GB 555 406 240/256GB 550 520 480/512GB 564 524 960GB/1TB 560 528 1920GB/2TB 560 530 NOTES: 1. The performance was measured using CrystalDiskMarkv5.0x64 with SATA 6Gbps host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of INSPIRE mSATA Parameter Rating Operating Voltage 3.3V +/-5% Table 2-3 Power Consumption of INSPIRE mSATA Parameter Power Consumption Idle (Max.) 0.43W Active (Max.) 2.40W NOTE: 1. Power Consumption may differ from flash configuration and platform. 3 2.3. TBW (Terabytes Written) Capacity TBW 64GB 95 128GB 191 256GB 384 512GB 769 1TB 1536 2TB 3065 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s INSPIRE mSATA is more than 2 million hours. 2.5. Data Retention  10 years if > 90% life remaining (@25C)  1 year if < 10% life remaining (@25C) 4 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -55°C ~ 95°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C~ 85°C Storage Humidity Silver Grade: 40°C, 95% RH Diamond Grade: 55°C, 95% RH Operating Humidity Silver Grade: 40°C, 93% RH Diamond Grade: 55°C, 95% RH Shock 1500G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit Bending ≥ 20N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 5 4. ATA COMMANDS Table 4-1 Supported ATA Command Set # Command Code Protocol Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Log Ext 2Fh PIO data-in Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in Read Verify Sector(s) 40h or 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Check Power Mode E5h or 98h Non-data Idle E3h or 97h Non-data Idle Immediate E1h or 95h Non-data Sleep E6h or 99h Non-data Standby E2h or 96h Non-data Standby Immediate E0h or 94h Non-data Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out General Feature Set Power Management Feature Set Security Mode Feature Set SMART Feature Set 6 SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Execute Off-Line Immediate B0h Non-data SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in SMART Return Status B0h Non-data SMART Save Attribute Values B0h Non-data Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Flush Cache Ext EAh Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Set Max Address Ext 37h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out Read FPDMA Queued 60h DMA Queued Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data Host Protected Area Feature Set 48-bit Address Feature Set NCQ Feature Set Others 7 5. PIN ASSIGNMENT Table 5-1 Pin Assignment and Description of INSPIRE mSATA Pin # mSATA Pin Description 1 NC No Connect 2 +3.3V 3.3V Source 3 NC No Connect 4 GND Ground 5 NC No Connect 6 NC No Connect 7 NC No Connect 8 NC No Connect 9 GND Ground 10 NC No Connect 11 NC No Connect 12 NC No Connect 13 NC No Connect 14 NC No Connect 15 GND Ground 16 NC No Connect 17 NC No Connect 18 GND Ground 19 NC No Connect 20 NC No Connect 21 GND Ground 22 NC No Connect 23 TXP (out) Host Receiver Differential Signal Pair 24 +3.3V 3.3V Source 25 TXN (out) Host Receiver Differential Signal Pair 26 GND Ground 27 GND Ground 28 NC No Connect 29 GND Ground 30 NC No Connect 31 RXN (in) Host Transmitter Differential Signal Pair 32 NC No Connect 33 RXP (in) Host Transmitter Differential Signal Pair 8 34 GND Ground 35 GND Ground 36 NC No Connect 37 GND Ground 38 NC No Connect 39 +3.3V 3.3V Source 40 GND Ground 41 +3.3V 3.3V Source 42 NC No Connect 43 GND Ground 44 NC No Connect 45 NC No Connect 46 NC No Connect 47 NC No Connect 48 NC No Connect 49 DAS Device Activity Signal 50 GND Ground 51 PD Presence Detection 52 +3.3V 3.3V Source 9 6. PHYSICAL DIMENSION Dimension: 50.8mm(L) x 29.85mm(W) x 3.83mm(H) 10 7. ORDERING INFORMATION Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSE064GBE-M500 FSSE064GBS-M500 60GB FSSE060GBE-M500 FSSE060GBS-M500 128GB FSSE128GBE-M500 FSSE128GBS-M500 120GB FSSE120GBE-M500 FSSE120GBS-M500 256GB FSSE256GBE-M500 FSSE256GBS-M500 240GB FSSE240GBE-M500 FSSE240GBS-M500 512GB FSSE512GBE-M500 FSSE512GBS-M500 480GB FSSE480GBE-M500 FSSE480GBS-M500 1TB FSSE001TBE-M500 FSSE001TBS-M500 960GB FSSE960GBE-M500 FSSE960GBS-M500 2TB FSSE002TBE-M500 FSSE002TBS-M500 1920GB FSSE1920BE-M500 FSSE1920BS-M500 Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSE064GBE-M50P FSSE064GBS-M50P 60GB FSSE060GBE-M50P FSSE060GBS-M50P 128GB FSSE128GBE-M50P FSSE128GBS-M50P 120GB FSSE120GBE-M50P FSSE120GBS-M50P 256GB FSSE256GBE-M50P FSSE256GBS-M50P 240GB FSSE240GBE-M50P FSSE240GBS-M50P 512GB FSSE512GBE-M50P FSSE512GBS-M50P 480GB FSSE480GBE-M50P FSSE480GBS-M50P 1TB FSSE001TBE-M50P FSSE001TBS-M50P 960GB FSSE960GBE-M50P FSSE960GBS-M50P 2TB FSSE002TBE-M50P FSSE002TBS-M50P 1920GB FSSE1920BE-M50P FSSE1920BS-M50P Power Loss Protection 11 AES 256 and TCG OPAL Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSE064GBE-M50S FSSE064GBS-M50S 60GB FSSE060GBE-M50S FSSE060GBS-M50S 128GB FSSE128GBE-M50S FSSE128GBS-M50S 120GB FSSE120GBE-M50S FSSE120GBS-M50S 256GB FSSE256GBE-M50S FSSE256GBS-M50S 240GB FSSE240GBE-M50S FSSE240GBS-M50S 512GB FSSE512GBE-M50S FSSE512GBS-M50S 480GB FSSE480GBE-M50S FSSE480GBS-M50S 1TB FSSE001TBE-M50S FSSE001TBS-M50S 960GB FSSE960GBE-M50S FSSE960GBS-M50S 2TB FSSE002TBE-M50S FSSE002TBS-M50S 1920GB FSSE1920BE-M50S FSSE1920BS-M50S Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSE064GBE-M50K FSSE064GBS-M50K 60GB FSSE060GBE-M50K FSSE060GBS-M50K 128GB FSSE128GBE-M50K FSSE128GBS-M50K 120GB FSSE120GBE-M50K FSSE120GBS-M50K 256GB FSSE256GBE-M50K FSSE256GBS-M50K 240GB FSSE240GBE-M50K FSSE240GBS-M50K 512GB FSSE512GBE-M50K FSSE512GBS-M50K 480GB FSSE480GBE-M50K FSSE480GBS-M50K 1TB FSSE001TBE-M50K FSSE001TBS-M50K 960GB FSSE960GBE-M50K FSSE960GBS-M50K 2TB FSSE002TBE-M50K FSSE002TBS-M50K 1920GB FSSE1920BE-M50K FSSE1920BS-M50K Hardware Write Protect 12 Revision History Revision Draft Date History 1.0 2019/08 Preliminary release 1.1 2020/02 Update Ordering Information 1.2 2021/05 Update capacity 1.3 2021/11 Update Ordering Information 13
FSSE120GBE-M500 价格&库存
很抱歉,暂时无法提供与“FSSE120GBE-M500”相匹配的价格&库存,您可以联系我们找货
