White Paper
A Rigado Best
Practices Guide
De-risking IoT Wireless Design
Leveraging certified modules and rapid iteration
White Paper De-risking IoT wireless design by leveraging certified modules and rapid iteration
Foreword
en we partner wit a new IoT client at igado t e first uestion we ask is
at will make t is product uni ue in t e
marketplace It s unlikely to be t e radio but too many companies underestimate t e time and e ort re uired to build a
robust wireless in rastructure be ore t ey even start t e c allenging process o developing t eir uni ue category-killing
product
T is paper covers two key strategies or IoT wireless design leveraging pre-certified modules to reduce risk and time to
market and planning or continued iteration via remote updates
ow power IoT wireless design is c allenging because t e very concept
o w ere a connected product begins and ends gets stretc ed across
ardware firmware local mes and device operations up in t e cloud
dd in IoT s constraints around si e unit cost mass distribution
and power consumption and it s clear t at or a success ul product
every aspect o t e wireless design must be care ully considered and
optimi ed
aving success ully deployed undreds o wireless pro ects across
consumer commercial and industrial markets we are appy to s are
our perspectives on ow to get products to market as uickly as
possible wit ma imum e ibility or t e uture and minimum risk to
bot sc edule and budget
Who should read this paper and why
2
CEO
ead t is paper to learn about t e business opportunities o remote updates allowing planned
iteration and ow to get to market uickly w ile minimi ing risk to your company
roduct
Manager
ead t is paper to understand t e risk actors o wireless design and ow to design or product
roll-outs t at scale massively wit minimal risk ou will also learn ow t inking o connectivity as a
plat orm or a amily o devices can c ange your I calculus and ow best to evaluate i and w en
to migrate rom modules to c ip-down designs
Design
Engineer
ead t is paper or specific best practices on ow to avoid t e most common mistakes w en
designing robust in rastructure or over-t e-air updates
Designing for iteration
ne o t e biggest advantages o IoT is t e ability to update configurations or add new unctionality a ter t e device
as le t t e actory but you ave to do some work up ront or e ample a well designed bootloader enables iterative
updates but re uires a robust process or managing t ose updates in t e field ou also need to mitigate t e risks o
re uent iteration by minimi ing downtime and designing ail-sa es against bricking t e device during updates
A Smart Bootloader
ll wireless o s will come wit some stock Device irmware pdate
D
unctionality but adding a couple o eatures to your bootloader
will cut your update risk actors by
inally end-to-end encryption protects you rom bot t e t o I
and malicious code being inserted onto your devices In t is case
end-to-end means encrypting t e update package all t e way
rom a system you totally control to t e IoT device itsel Don t
rely on t e luetoot connection s de ault encryption instead you
s ould s are t e keys at t e point o manu acture via a ardwire
connection at t e actory T is ensures t at even i t e connection
is compromised no rogue firmware can be loaded on t e device
PROTIP
SOFTWARE
econd you s ould always include a double bu er T is allows you
to veri y updates be ore t ey re loaded e sure t at t e bu er is
large enoug
s ould be su cient
FIRMWARE
SMART
BOOTLOADER
irst t e bootloader D s ould e ist outside o t e main
application firmware T is ensures t at t e device can start up
regardless o t e condition o t e application firmware
RADIO
Figure 1. Smart Bootloader ake sure your bootloader
is independent o your firmware
To save time and minimi e t e risk o uman error any ongoing update management process
s ould be as automated as possible so make sure you ave a robust and well-documented I
Unique Key Encryption: Only the paranoid survive
I someone as p ysical access to a device and t ey are determined enoug you s ould assume t e device can be acked o t e
uestion to answer is ow e posed am I i someone acks one device
igado uses
-bit
encryption to secure t e trans er o firmware images to our modules but we also employ device-specific
encryption keys to reduce t e t reat o a single success ul ack turning into a ma or irai botnet-level catastrop e
T is re uires some e tra development work up ront or use a module t at as secure bootloader already integrated but wit your
companys entire reputation at stake plus t e potential e pense o a recall t e risk-reward calculation skews ig ly in avor o playing it sa e
3
Managing updates at scale
To update t e devices in t e field you will need a central device
operations application t at is in communication wit eac device T is
cloud application will probably ave ot er unctionality e g processing
data rom device sensors or issuing instructions to t e device but we re
ocusing ere on update management
T e first re uirement o t e device operations app is to identi y and group
devices our device operations system needs to track w ic uni ue
devices ave w at eatures enabled and ideally w ere t ey are deployed
e g to roll out updates at o -peak ours time one by time one
w ic makes eature management a lot easier Tags can elp manage
ardware variations too making it easier to deploy di erent versions o
an update to support di erent ardware wit out aving to add serial
number-level logic into your updates
inally aving granular command o device selection enables staggered
roll-outs w ic dramatically reduces t e risk o catastrop ic update
ailure staggered roll-out updates a small percentage o devices first
waits or an acknowledgment t at t e update went well and t en rolls
out t e update in larger and larger co orts eac time c ecking or a
eartbeat be ore proceeding to t e ne t co ort
y adding support or device tags in bot your firmware design and
your cloud app you can assign specific devices to one or more groups
Minimize your risk with differential updates and roll-back failsafe
onsumers regularly complain about automated updates interrupting
t eir use o t eir digital devices In industrial applications you can
actually measure t e cost o downtime due to updates In eit er
case downtime translates to dissatis action t t e ot er end o t e
rustration spectrum t ere is t e possibility o a bad update totally
bricking t e device
Di erential updating also results in a better customer e perience as
downtime during update can decrease rom minutes to seconds T is
can really add up or devices w ere updates are pus ed re uently
especially at t e beginning o t e product li ecycle w ere t e owner
is evaluating t e total cost o owners ip o t e device w ic includes
t e rustration actor versus its value
igado as developed a uni ue solution or minimi ing t e si e and
time o over-t e-air T updating t roug t e use o di erential
updating di erential update contains only t e c anged parts o t e
firmware not t e entire image
ood update design includes building in ailsa es dd logic to
your bootloader D to do a c ecksum on t e update and veri y it
transmitted success ully be ore you write over t e firmware image
T en move a copy o t e original firmware into t e bu er w ile t e
device reboots I t e new firmware ails to boot success ully t en
ave t e bootloader swap out t e firmware images and roll-back to t e
earlier version t at was working
T ere are di erent degrees o di erential you mig t only update at t e
library level or wit t e rig t firmware in t e bootloader you can di
down to a single line o code t igado we o ten reduce t e update
si e by
or more w en we use di erential updates
at s more smaller update packages means less data w ic also
means less power re uired or transmitting updates
ou will need to add logic so you dont get caug t in an update and roll-back
loop and make sure t e bootloader reports back to t e device
management application wit details about t e ailed update t t at
point your operations so tware can send instructions to try again or
alert you to fi t e issue and start again wit a new version
DEVICES
GATEWAY
DEVICE
OPERATIONS
DEVICES
GATEWAY
Figure 2. Managing updates our Device perations cloud app communicates wit and manages devices via a gateway
4
Getting to market faster & planning for scale
I time to market is important to your product s success t en leveraging a pre-certified module s ould be your de ault
strategy
ile pre-certified modules carry a slig tly ig er per-unit price t an a custom designed wireless or c ipdown solution t ey typically save ar more in design certification costs or new products good rule o t umb is
to leverage t e speed and implementation advantages o module solutions until you e ceed
units and t en
evaluate migrating to a custom c ip-down solution
T is section will look at t e time savings o leveraging a module solution and t e advantages o designing your
connectivity solution as a plat orm or all uture members o t e product amily
De-Risking Part 1:
Testing the product value proposal
De-Risking Part 2:
Minimizing regulatory risk & certification costs
very product manager s goal is to bring t eir product to market as
uickly as possible at t e lowest possible cost so t ey can test t eir
market assumptions and see i t ey truly ave a winner
en you design your own radio you are considered an intentional
radiator by t e
and as suc must comply wit
T ese re uirements ave undreds o tests w ic can take mont s
and cost tens o t ousands o dollars
at s more c anging t e
antenna ground plane
firmware board layout or even t e casing
can all trigger re-certification etting t ese all per ect t e first time is
unlikely so i you decide to do it yoursel t en you s ould actor in at
least two rounds o certification be ore going to market at scale
ireless modules o ten allow you to bring connectivity to a product
or less t an al t e cost o designing your own wireless solution
so you can evaluate t e product s potential be ore laying out a uge
investment in wireless engineering e pertise and global certifications
it so muc engineering work completed in advance you get to
market aster giving you more time to iterate based on customer
eedback and first mover advantage over your competitors
Design
Module
In contrast leveraging a pre-certified radio module makes you an
unintentional radiator w ic as a muc easier certification ou also
ave t e benefit o a market-tested design w ere any re-designs and
re-certifications will be t e responsibility o t e module vendor
Implementation
Evaluate & Select
Wireless Module
ertification
Non-Intentional ertification
for End Product
aunc
Launch Quickly!
VS
Chip
Down
Evaluate
& Select
Wireless
SoC
Antenna
Designs
Custom Wireless Firmware
Custom Wireless Software
Board
Designs
Performance
& Compliance
Testing
Custom Updating Tools
TYPICALLY MULTIPLE CERTIFICATION
TESTS & DESIGN ITERATIONS REQUIRED
Figure 3. Timeline of two engineering teams Modules reduce risk, cost & time to market.
Submit For
Intentional
Radiator
ertification
TYPICALLY ADDS
4-6 MONTHS
TO LAUNCH
Connectivity as a platform
iven t e cost and comple ity o designing a wireless connectivity
solution it makes sense to reuse your designs as o ten as possible
en we re talking wit our clients we strongly recommend t ey t ink
o connectivity as a plat orm or an entire amily o products rat er
t an as a one-o design e ercise or a single device it a plat orm in
place new product amily members can get to market wit near- ero
engineering time or connectivity aring parts across a amily also
makes it easier to buy in bulk w ic reduces
cost and inventory
management always a concern w en scaling
Making the move from module to custom design
odules incorporate t e tools you need or ast iteration but t ey re
typically a bit more e pensive so at some point you may need to make
a decision about i and w en to move rom modules to a c ip-down
design
rom an engineering perspective t e process is ust a part swap you
can use t e same o in your custom design t at t e module uses
and you can probably license any firmware or libraries t at t e module
provider included ut as t e designer o a radio transmitter you will
now need a di erent type o certification and by stripping out e tra
eatures in avor o a bare-bones design you may be limiting your
options to add new eatures in t e uture
PROTIP
en looking at connectivity as a plat orm taking steps to uture
proo t at plat orm is o ten a wise investment or e ample you may
want to select a dual mode wireless o t at supports bot luetoot
and T read even i only one will be used initially ou will also want to
ensure you ave ade uate
memory sensors and I
or uture
apps
inally you s ould consider w ere you ll be selling as eac country as
its own certification re uirements t igado our modules are all
I and apan certified and
and ustralia ew ealand compliant
valuating t e move rom odule to ip Down
re e pected
savings cost o design test certification
ou s ould also consider engineering opportunity cost ay a c ipdown design saves
per unit sold but it will take mont s o
engineering time to get t ere
ould you generate more revenue i t e team used t at time to work
on new innovations t at leverage your company s uni ue skill set
ltimately migrating to a custom c ip-down design may be t e rig t
move once a device reac es volumes o
or more T at s also a
transition t at your module provider s ould be able to acilitate
ake sure your module provider as a well documented process to migrate your firmware and app code
to a custom design or e ample will t ey license any proprietary firmware to your custom design
Production Volume
v2.0
v1.0
Use a module to
get first version to
market faster. Save
on design and
certifiication costs
and focus on
unique value-added
features
Reuse wireless
platform to quickly
expand product line
and iterate
products in the
field as needed
v3.0
After product reaches
high volume, leverage
module provider
team to migrate to
chip-down design
to reduce BOM
cost across family
Time
Figure 4. Getting to market & when to scale: ook at sales volume to decide i and w en to move to a custom wireless design
6
Summary: Wireless design is challenging, but best
practices help
IoT revolutioni ed product design wit t e ability to update devices remotely opening t e door to a design p ilosop y o
planned iteration and ongoing revenue models wit mont ly subscriptions
It’s all about your product’s unique value-add.
s long as you design wit security in mind rom device firmware to cloud operations and you invest resources in robust
over-t e-air updates your products can continue to evolve long a ter t ey ve le t t e actory generating new revenue
streams and delig ting users or years
s engineers ourselves we recommend you consider a module-based design or look at partnering wit a wireless design
ouse It allows your team to ocus on w at makes your product uni ue minimi es risk and dramatically decreases time
to market
To take a closer look at t e most likely risk actors acing your wireless pro ect contact us at in o rigado com
About the author
Justin Rigling, Co-Founder and Chief Technology Officer, Rigado
s T at igado ustin as designed literally undreds o wireless modules or every
application imaginable rom bike computers to eavy industry to gol course watering sensors
rior to co- ounding igado in
ustin was a design engineer at armin International e
speciali es in low-power wireless systems and olds a
in lectrical ngineering rom IT
ustin is invited to speak regularly at industry events and e is a member o t e luetoot
pecial Interest roup t
miles e also set t e uinness book world record alongside
igado co- ounder en orrado or t e world s longest wi-fi connection
7
I D orporation
ll rig ts reserved
www rigado com
很抱歉,暂时无法提供与“BMD-100-A-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+116.291991+14.11729
- 10+105.2332610+12.77482
- 25+96.9281125+11.76661
- 100+88.61871100+10.75789
- 250+83.08003250+10.08552
- 500+77.54153500+9.41317
- 国内价格 香港价格
- 1000+73.664491000+8.94252
