BD-100
BD-100
    AUTONICS(奥托尼克斯)
    LASER DISPLACEMENT SENSOR 100MM
BD-100 数据手册
BD Series Laser Displacement Sensor ▣ Features ● Easy maintenance with separable structure of sensor head/amplifier unit ● Maximum resolution: 1μm (different by models) ● Stable measurement regardless of color or material of the object ● Mutual connection up to 8 amplifier units : Interference prevention and channel alignment are automatically applied ● Various calculation function (add, subtraction, average) ● Various filter function for stable measurement (average, differential, median) ● Teaching modes configuration (1-point, 2-point) for user environment Sensor head ● Mounting on DIN-Rail or wall (accessory bracket is needed) is available ● Sensor head IP67 protection structure (patented) : Korea patent application number 2017-0043925 Amplifier unit Please read “Safety Considerations” in the instruction manual before using. ▣ Manuals For the detail information and instructions, please refer to user manual for communication, and be sure to follow cautions written in the technical descriptions (catalog, website). Visit our website (www.autonics.com) to download manuals. ▣ Model (unit: mm) : Attaching location of ferrite core Max.30 Sensor head ◎ Sensor head Model Beam shape Reference distance (Maximum measurement range) BD-030 Standard 30mm (20-40mm) BD-065 Standard 65mm (50-80mm) BD-100 Standard 100mm (70-130mm) ◎ Amplifier unit Model BD-A1 Compatible sensor head BD series sensor head: 1 Max.30 Extension cable (sold separately) Spot diameter Near Reference Far Approx. 360×1590㎛ (at 55mm) Approx. 290×1180㎛ (at 65mm) Approx. 210×830㎛ (at 75mm) Approx. 290×790㎛ (at 25mm) Approx. 240×660㎛ (at 30mm) Approx. 480×1870㎛ (at 80mm) Approx. 410×1330㎛ (at 100mm) ◎ Extension cable (sold separately) Model Length CID6P-2-SI-BD 2m CID6P-1-SI-BD CID6P-5-SI-BD CID6P-10-SI-BD E-6 Amplifier unit 1m 5m 10m Approx. 190×450㎛ (at 35mm) Approx. 330×950㎛ (at 120mm) -|Transparent setting guide|- Laser Displacement Sensor ▣ Specifications Sensor Head Model BD-030 Spot diameter (unit: ㎛) Near (25mm) Approx. 290×790 Reference (30mm) Approx. 240×660 Far (35mm) Approx. 190×450 BD-065 Near (55mm) Approx. 360×1590 Approx. 290×1180 Far (75mm) Approx. 210×830 BD-100 Near (80mm) Approx. 480×1870 Approx. 410×1330 1㎛ Maximum measurement range 20-40mm 50-80mm 70-130mm 0.1% F.S. (in 25 to 35mm) 0.1% F.S. (in 55 to 75mm) 0.15% F.S. (in 80 to 120mm) Linearity※1※2 Temperature Characteristics※3 Power supply ※4 Light Source Optical method Laser class Output 30mm 0.05% F.S./℃ - 65mm 0.06% F.S./℃ 4㎛ Reference (100mm) Resolution※1 Reference distance 2㎛ Reference (65mm) Red semiconductor laser (wavelength: 660nm, IEC 60825-1:2014) Diffuse reflection Class 1 (IEC/EN), Class I (FDA(CDRH) CFR Part 1002) Max. 300㎼ Class 2 (IEC/EN), Class II (FDA(CDRH) CFR Part 1002) Max. 1㎽ Power indicator: red LED, Laser emission indicator: green LED, NEAR/FAR indicator: green LED Insulation resistance Over 20MΩ (at 500VDCᜡ megger) Noise immunity Approx. 330×950 100mm Operation indicators Connection Far (120mm) Connector type Square shaped noise by noise simulator (pulse width: 1㎲) ±500V Dielectric strength 1,000VAC 50/60Hz for 1 minute Vibration Shock Environment Ambient illumination Ambient temperature Ambient humidity Protection structure Material Amplifier unit compatibility Accessory Approval Weight※5 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours 300m/s2 (Approx. 30G) in each X, Y, Z direction for 3 times Max. Incandescent lamp 10,000㏓ -10 to 50℃, storage: -15 to 60℃ Under 85%RH, storage: under 85%RH IP67 (IEC Standards, except connector of extension cable) Case: Polycarbonate, Sensing part: Glass, Cable: Polyvinyl chloride BD Series amplifier unit: 1 Ferrite core (made by TDK co. ZCAT2132-1130), Mounting bracket, Bolt, Nut Approx. 209g (approx. 56g) Approx. 233g (approx. 68g) Approx. 233g (approx. 68g) ※1: When measuring fixed non-glossy white paper (reference temperature: 25℃, reference distance, response time: 1ms, average 128 times). ※2: Value indicates the error with respect to the ideal straight line and the numbers in parentheses are the rated measurement ranges guarantee linearity. ※3: Value measured by using an aluminum jig fix the sensor head and non-glossy white paper. ※4: Using power from the amplifier unit. ※5: The weight is with packaging and the weight in parenthesis is only unit weight. ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation environment. E-7 -7 BD Series Specifications Amplifier unit Model BD-A1 Power supply Power consumption※1 Timing Control input ※2 Output reset Laser OFF Zero adjustment Bank change Judgment output (HIGH/GO/LOW) Alarm output Analog output※3 Residual voltage Voltage Current Protection circuit 10-30VDCᜡ ±10% (When connecting BD-C Series communication converter, 12-30VDCᜡ) Max. 2800mW (30VDCᜡ) No-voltage input NPN or PNP open collector output (Load current: Max. 100mA) NPN or PNP open collector output (Load current: Max. 100mA) -5-5V, 0-5V, 1-5V (Resistance: 100Ω, ± 0.05% F.S., at 10V) 4-20mA (Max load resistance: 350Ω, ± 0.2% F.S., at 16mA) NPN: Max. 1.5V, PNP: Max. 2.5V Reverse polarity protection circuit, output overcurrent (short-circuit) protection circuit Response time 0.33, 0.5, 1, 2, 5 ms (5-step adjustment) Min. display unit 1㎛ Display method Dual display by 6-digit, 11-segment LED Display range※4 ±99.999mm to ±99mm (4-step adjustment) Insulation resistance Over 20MΩ (at 500VDCᜡ megger) Display period Noise immunity Dielectric strength Environment 1.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Ambient temperature Ambient humidity Protection structure Material Connection Sensor head compatibility Accessory Approval Weight※5 Square shaped noise by noise simulator (pulse width: 1㎲) ±500V 1,000VAC 50/60Hz for 1 minute Vibration Shock Approx. 100ms 300m/s2 (Approx. 30G) in each X, Y, Z direction for 3 times -10 to 50℃, storage: -15 to 60℃ Under 85%RH, Storage: under 85%RH IP40 (IEC Standards) Case: Polycarbonate, Cover: Polycarbonate, Cable: Polyvinyl chloride Connector type BD Series sensor head: 1 Mounting bracket, Side connector Approx. 228g (approx. 126g) ※1: Power to the load is not included. ※2: Use after assigning to external input line. For the details, refer to the item in '▣ Parameter group'. ※3: It is possible to use among -5-5V, 0-5V, 1-5V, 4-20mA by parameter setting. ※4: Setting range is assigned automatically when connecting sensor head. ※5: The weight is with packaging and the weight in parenthesis is only unit weight. ※The temperature or humidity mentioned in Environment indicates a non freezing or condensation environment. E-8 -|Transparent setting guide|- Laser Displacement Sensor ▣ Unit Description ◎ Sensor head 1 POWER LAS ER ▲ FAR 2 ▲ 3 NEAR 1 Power indicator (red) 5 2 Receiver 6 3 4 4 5 7 6 8 7 8 ◎ Amplifier unit 12 11 4 6 1 2 3 4 5 6 ◀ 2 5 Receives reflected laster from the object. Emitter Emits laser to the object to measure the displacement. Emission center line The line and the object should be aligned because the laser is emitted along the line. Laser emission indicator (green) Lights ON during sensor head emits laser. NEAR/FAR indicator (green) Out of the rated measurement range: Flashing Near the reference distance: Turns ON. Mounting hole Connector cable 10 1 3 Indicates whether power supply the sensor head. ▲ ▶ ▼ 7 8 Present value (PV) display: Red Displays PV, calculating result (when using calculation), parameter name (when setting parameter). Setting value (SV) display: Green Displays SV (HIGH, LOW, RV, Analog output, Bank), parameter setting value (when setting parameter). The type of displaying SV can be recognized by Setting value (SV) indicator recognition . Judgment indicator: Red (HI/LO), Green (GO) Lights ON when outputting judgment value following to SV. Alarm indicator: Red Lights ON when outputting alarm. Optimization setting key [AUTO] Executes Sensing optimization . Setting value (SV) indicator recognition lamp: Green Displays the value type of Setting value (SV) display 9 7 Zero adjustment setting key [ZERO] 8 Mode setting key [MODE] 9 Executes Zero adjustment . Enters modes and sets the parameter value. Direction key [◀/▶/▲/▼] Sets the value of mode and parameter. 10 Calculation indicator (CALC): Green Lights ON when using calculation. 11 Measurement range indicator (RANGE): Green Lights ON when PV is in the measurement range, lights OFF when PV is out of the measurement range or emitting laser is stopped. 12 Laser emission indicator (LASER): Green Lights ON when emitting laser. HI/LOW: HIGH/LOW judgment value RV: Real distance value ANALOG: Analog output E-9 -9 BD Series ▣ Dimensions 42.5 4.5 22 Ø3.2 2-Ø3.2 2-Ø3.2 2-R46.7 40.5 25 15° 9.2 57.5 • BD-065/100 44.1 34.1 2-5° 3 39.6 29.7 2-Ø2 3.5 12.6 Ø4.2, 0.5m 5.6 20 54 43 2-Ø3.2 9.1 1.6 2-Ø3.2 ● Ferrite core (accessory) 32 60.5 48.5 Ø20 34 Ø3.2 22.5 2-Ø2 8.85 2-R52.7 1.6 ● Bracket 35 21 13 ◎ Amplifier unit 3.5 16 ● Brackets • BD-030 8.6 15° Ø4.2, 0.5m 3 3 19.5 Optical axis of emitter 49.5 Optical axis of emitter 25.3 6.1 38 44 51 4 (unit: mm) • BD-065/100 2-8° • BD-030 13.3 ◎ Sensor head 6-R1.6 3.6 Ø4.8, 2m 8.9 ● Extension cable (sold separately) E-10 32.4 12.3 35mm DIN rail 31.7 2 2-Ø3.2 7 14 31.2 2-Ø1.9 1 8.5 6.5 2 87.35 37.1 22.6 30 27 -|Transparent setting guide|- Laser Displacement Sensor ▣ Connections Item Code color Description Blue Common GND (input, output, power) Brown Power Black HIGH Judgment Orange LOW Judgment Gray GO Judgment Green Output Alarm Analog: Following parameter value (-5-5V, 0-5V, 1-5V, 4-20mA) White GND (Analog output) ※It is needed to distinguish from common GND. Shield Pink External input 1 Yellow External input Power: 10-30VDC External input 2 Red External input 3 Purple External input 4 ▣ Control Output Diagram ◎ Judgment (High, Go, Low) and alarm output PNP open collector output Output short over current protection circuit Output short over current protection circuit Connection Load Load (black)OUT0 (orange)OUT1 (gray) OUT2 (green) OUT3 (blue)GND Load Max.100mA 30VDC (brown)+V (black)OUT0 (orange)OUT1 (gray) OUT2 (green) OUT3 (blue)GND 30VDC Max.100mA - + (brown)+V ◎ Analog output  (-5-5V, 0-5V, 1-5V, 4-20mA) mA + - + NPN open collector output Main circuit Inner circuit Main circuit Item Select parameters as below and input a signal to execution. (Timing, Output reset, Laser OFF, Zero adjustment, BankA, BankB, OFF) + White - - Shield Load ▣ Installation Procedures For optimum measurement, install the sensor head according to the following procedure. Order Chapter 1 Check reference distance and select mounting location Description 2 Check the precautions about the measurement 3 Check mounting method and mount In case of measuring moving or rotating object, it is needed to install the sensor head to correct direction. When measuring at narrow area or concave object, it is needed to set the position of the sensor head. For the details, refer to '▣ Installation Precautions'. 4 Check and apply the function of amplifier unit. As the distance between the sensor head and the object approaches the reference distance, accurate measurements can be made. Refer to '▣ Mounting Location' to select optimum mounting location. Mount to the panel directly or through the enclosed bracket. Refer to '▣ Mounting and Connecting Method' to mount the sensor head. BD series support various settings and functions such as pitch light optimization, zero adjustment setting, automatic sensitivity setting, calculation through the amplifier unit. E-11 -11 BD Series ▣ Mounting Location Select mounting location regarding displacement of the object, reference distance and measurement range. Mount sensor head where the object is located at the reference distance by checking the operation of indicators and displacement value. ◎ Indicator display Check the operation of indicators to know distance between sensor head and the object. Distance between the sensor head and the object NEAR indicator (green) Rated measurement range※ Reference distance Reference distance± (Rated measurement range×10%) OFF ON FAR indicator (green) Crossflashing Power indicator (red) Laser emission indicator (green) • NEAR/FAR indicators turn on, off and cross-flashing by the distance between the sensor head and the object and the indicator are on both, it means the sensor head is located in optimum area near reference distance. • Power indicator is on when power is supplied. • Laser emission indicator is on during laser emission. ※The linearity guaranteed measurement range. ◎ Displacement indication The value is displaced more positive (+) as the object is closer to sensor head, more negative value (-) as the object is far from sensor head relative to the origin (0). Reference distance (+) (0) (-) ◎ Indication by distance Model Rated Reference measurement distance ※ range BD-030 30 BD-065 65 BD-100 100 25 to 35 55 to 75 80 to 120 Rated measurement range Indication NEAR ON 25 to 31 55 to 67 80 to 104 ※The linearity guaranteed measurement range. E-12 ※ (unit: mm) NEAR/FAR ON 29 to 31 63 to 67 96 to 104 FAR ON 29 to 35 63 to 75 96 to 120 -|Transparent setting guide|- Laser Displacement Sensor ▣ Mounting and Connecting Methods ◎ Sensor head Mounting ◎ Connecting to amplifier unit M3 bolt M3 nut ① Side amplifier unit to ⓐ direction. ② Pull the assembly part to ⓑ direction to detach. ◎ Ferrite core (accessory) Sensor head m 30m • Within 30mm from the sensor head, wind the cable through the inside of the ferrite core three times and mount the ferrite core. Extension cable (sold separately) m 30m • Within 30mm from the connector of amplifier unit, wind the cable through the inside of the ferrite core three times and mount the ferrite core. ① Remove the side cover at the connecting side. ② Connect the side connector to the units. ③ After mounting amplifier unit on DIN rail, push it to arrow direction tightly. ※In case of disconnecting, follow the upper sequence reversely. Distinguishing master/slave amplifier units • When the power cable direction is down, the amplifier at the left end is the master unit, and the channel number of slaves increases sequentially to the right. Master Slave SLAVE 7 ⓐ ③ SLAVE 6 ⓑ ① SLAVE 5 • Detaching ① Insert the bottom holder of amplifier unit to 35mm width DIN rail. ② Push the front part of the unit to arrow direction to mount. ② SLAVE 4 Mounting on DIN rail • Mounting ◎ Connecting amplifier units mutually SLAVE 3 Mounting with bolt • Mounting without DIN rail is possible by using bracket. • The method of mounting and detaching with bracket is as same as DIN rail. SLAVE 2 ◎ Amplifier unit Mounting ① Connecting: Insert connector of the sensor head into amplifier unit with aligning ↑ mark and ▲ mark until it sounds click. ② Disconnecting: Pull out the connector cap of sensor head to the opposite direction. ※Do not supply the power when connect / disconnect sensor head to amplifier unit. SLAVE 1 • Check the mounting position considering emission center line, vibration and shock. • Mount to the panel directly or through the bracket by using M3  bolt and nut. • Tighten the bolt with 0.5N·m torque when mounting. MASTER Emission center line ※Max. 8 units Precautions when connecting amplifier unit • Mount on DIN rail. • Do not supply the power when adding amplifier unit. • Supply power to each connected amplifier unit at the same time. • Up to 8 amplifier units can be connected, and only 1 calculation function can be performed per 1 group of mutually connected amplifiers. • When the calculation function is activated, the setting values (SV)​​ of the slave units are disable and the mutual interference prevention function for sensor heads is executed automatically. E-13 -13 BD Series ▣ Installation Precautions For stable measurement, mount the sensor head by referring to the below items. ◎ Moving object measurement 1. Object with material / color difference Install the emitter and receiver in parallel to the material or color boundary of the object. 2. Rotating object Install the receiver and the rotating shaft in parallel to minimize the influence of fluctuations and position deviations. 3. Object with step Install the emitter and receiver vertically to the line between crest and valley of the object. ◎ Narrow area or concave object Install the sensor head where the reflected laser beam does not blocked toward the receiver part. ◎ Wall mounting Install the sensor head where the reflected laser beam from the wall does not enter the receiver part. If the color of wall is black with low reflectivity and no gloss, the error can be minimized. ◎ Black object When measuring black object with low reflectance the amount of light received decreases, install the sensor head closely to the object. E-14 -|Transparent setting guide|▣ Parameter Setting Mode Key Run mode Sensing optimization [AUTO] key over 2 sec Zero adjustment [ZERO] key over 2 sec Laser Displacement Sensor Description Present value (PV) display • Solo: Displays present value (PV). • When using calculation: Displays the result of calculation, and calculation indicator (CALC) of master amplifier unit turns on. Setting value(SV) display Can change the type of value by the [◀/▶] keys, and each recognition lamp turns on. Setting range: HIGH setting value, LOW setting value, real distance value (RV), analog output, bank (Displays [BANK-□] and all the recognition lamps turn off.) Optimizes the level of laser emission and receiving sensitivity regarding the object color and environment. Execution: Execute automatically when entering the mode. Sets the present value (PV) to the reference distance forcibly. Execution: After entering the mode, push the [ZERO] key within 1 sec, or apply the signal to external input wire for zero adjustment over 3 sec. Dismiss: P  ush the [ZERO]+[MODE] keys over 2 sec, or apply the signal to external input wire of zero adjustment over 3 sec. ※If the present value is changed by zero adjustment, the setting values (HIGH SV, LOW SV etc.) are not changed. HIGH sensitivity [MODE]+[▲] key Sets the judgment output (HIGH/GO/LOW) range by manual input. adjustment over 2 sec Can change the number of digit by the [◀/▶] keys, and setting value by the [▲/▼] keys. LOW sensitivity [MODE]+[▼] key The recognition lamps display the type of sensitivity adjustment. adjustment over 2 sec Set the judgment output (HIGH/GO/LOW) range automatically. Enter the auto sensitivity adjustment setting mode after set the type of teaching mode in parameter 1 group. • 1-point teaching Sets the judgment output range by using present value (PV) of reference object height. HIGH setting value=height present value×1.5 LOW setting value=height present value÷2 Setting: 1  . '1P' is displayed on setting value (SV) display, push the [AUTO] key within 2 sec. 2. After teaching the object for 2 sec, set the judgment output range automatically by applying the result. Auto sensitivity adjustment (Teaching) [MODE] key within 2 sec Control output type Sets the type of control/analog output. Setting: Select the setting value by [▲/▼] key, and apply by [MODE] key. • Setting range control output 'OUT': NPN output 'NPN', PNP output 'PNP' [MODE]+ [AUTO] analog output 'A-OUT': Disable 'OFF', 4-20mA current output '4-20MA', key over 2 sec 0 to 5V voltage output '0-5V', 1 to 5V voltage output '1-5V', -5 to 5V voltage output '-5-5' After setting is finished, flashes 'OUtSET' on present value(PV) display and 'END' on setting value (SV) display 3 times, and returns to run mode. HIGH PEAK value LOW PEAK value Parameter group [▲] key [▼] key [MODE] key over 2 sec • 2-point teaching Sets the judgment output range by using present value (PV) of reference object step. HIGH setting value=(step×1.5)+bottom height LOW setting value=(step÷2)+bottom height Setting: 1  . '1P' is displayed on setting value (SV) display, push the [AUTO] key within 2 sec. 2. After teaching the object for 2 sec, '2P' is displayed on setting value (SV) display, push the [AUTO] key within 2 sec. 3. After teaching the object for 2 sec, set the judgment output range automatically by applying the result. Displays HIGH/LOW PEAK value. If there is direction key input or no key input for 5 sec, returns to run mode. If push the [▲/▼] key over 3 sec during HIGH/LOW PEAK value display mode, initializes the value. If there is no value, displays 'HHHH' / 'LLLL'. Enters to the parameter group 1 to 4. E-15 -15 BD Series ▣ Parameter Group • Push the [MODE] key over 2 sec to enter the parameter setting mode. • In the setting mode, change the parameter group by the [◀/▶] keys and enter the group by pushing the [MODE] key. • In the group, change the parameter by the [◀/▶] keys, select it by pushing the [MODE] key, and change the setting value by [▲/▼] keys • In the each step, push the [MODE] key over 3 sec to save and return to the upper step. ※Some parameters are enable by related parameter setting. Parameter group 1 PARA1 Settings related to output type, displacement, display and error output. Parameter Response time Teaching SENS mode RSPD NoNC Output type DISP PV display Display DOT digit H-SC Display L-SC scale HYS Hysteresis H-AN Analog output L-AN scale Error ERrOUT output Fixed FIxOUT output Setting range 330㎲, 500㎲, 1ms, 2ms, 5ms 1PNT 2PNT NO NC STND SCALE 1-point 2-point Normally open Normally closed Standard Scale 0.000, 0.00, 0.0, 0 PARA3 Default 1ms 1PNT D-IN4 -99.999 to 99.999 Different by models Set analog output range 0.001 KEEP Max. value Parameter group 2 Settings related to present value. Parameter Setting range Default OFF Off ADD-AB Add CALC Calculation OFF SUB-AB Subtraction AVG Average mode GAIN Gain 1, 2, 3 1 AVF Average filter FILTER Filter AVF DIFF Differential filter Samples for 1, 2, 4, 8, 16, 32, 64, 128, 256, AVF 16 averaging 512, 1024, 2048, 4096 Samples for MEDIAN OFF, 3, 5, 7, 15, 31 OFF median OFF Off PEAK Peak BOTTOM Bottom OFF HOLD Hold P-P Difference SAMPLE Sample AVG Average T-IN External input AtUP Over auto trigger Hold timing level T-IN HOLdT input AtDW Under auto trigger level Auto trigger AtLV -99.999 to 99.999 0 level Auto trigger AtHYS 0.001 to 99.999 0.001 hysteresis OFF Off T-MOD Timer OND Output delay OFF OFD Output hold TIME Timer value 0 to 9999 0 PARA2 E-16 D-IN2 STND -99.999 to 99.999 KEEP Keep PV FIX Fixed value D-IN1 D-IN3 Different by models 0.001 to 99.999 Parameter NO 0.000 Parameter group 3 Settings related to external input. External input 1 External input 2 External input 3 External input 4 Setting range OFF T-IN OUtCLR L-OFF ZERO BANK-A BANK-B Off Timing input Output reset Stop emission Zero adjustment Bank input-A Bank input-B Default T-IN OUtCLR L-OFF ZERO Parameter group 4 Settings related to user convenience functions. Parameter Setting range Default Display [▲/▼] (select direction) Normal DIR direction → [MODE] (apply) display BANK-0,,BANK-1 BANK-0 BANK Bank BANK-2,,BANK-3 OFF Off Saving SAVE SAVE1 Digital display OFF mode SAVE2 All display OFF Off LOCK1 [AUTO], [ZERO] LOCK2 [AUTO], [ZERO] LOCK Lock mode +entering parameter OFF group LOCK3 All key (except unlock key) OFF, CLR-B0, CLR-B1, OFF INIT Initialize CLR-B2, CLR-B3, CLR-A PARA4 ※Parameter group 4 is common, not saved per bank separately. -|Transparent setting guide|▣ Display When Power is ON Laser Displacement Sensor Displays control output setting screen when connecting a sensor head and supplying power at the first time, or replacing a sensor head. Set the output type as below sequence. Refer to '▣ Parameter setting' to check the setting range and the reset method. ▲ ▲ ◀ ◀ ▶ ◀ ▼ ▼ ① When 'OUT' is displayed on the present value (PV) display, select control output type through the [▲/▼] keys and push the [MODE] key. ▲ ▶ ② When 'A-OUT' is displayed on the present value (PV) display, select analog output type through the [▲/▼] keys and push the [MODE] key. ▶ ▼ ③ After 'OUtSET' is flashed three times and it returns to the run mode. ▣ Error Display In error status, 'ERROR' is displayed on present value (PV) display. Deal with an error by referring to the below solution of each setting value (SV) display. Setting value (SV) Output Reason display Disconnection of sensor head/ HEAD O amplifier unit/cable Sensor head malfunction LASER DARK RANGE BRIGHT ------ O - A-MEM O H-MEM O AMP-C O VER O OUT O AUTO - Malfunction of emission Not existing the object or background in maximum measurement range Over receive the light In status of display unavailable Amplifier unit memory malfunction (EEPROM cannot be refreshed due to exceeding the number of recording over 1 million times) Sensor head memory malfunction Poor connection between amplifier units. Mismatch the version of firmware between sensor head and amplifier unit. Disconnection of the judgment output Teaching failure AMP O Amplifier unit error oCUR O Over current of output terminal Solution Check the connection between sensor head and amplifier unit. Check the disconnection of sensor head cable. Perform the above items and supply the power again. If the problem is not resolved after the above items are performed, it is judged that the sensor head is defective and needs to be replaced. Adjust the distance between sensor head and object in the maximum measurement range. Return to status of present value display available. Turn off the power, check the connection of sensor head, and supply the power again. Executes the initialize 'INIT' function. If the problem is not resolved after the above items are performed, it is judged that the amplifier unit is defective and needs to be replaced. Turn off the power, check the connection of sensor head, and supply the power again. If the problem is not resolved after the above item is performed, it is judged that the amplifier unit is defective and needs to be replaced. Check the connection between amplifier units, and supply the power again. Please contact the Autonics technical advisory center. After turn off the power, check connection of HIGH (black) / GO (gray) / LOW (orange) wire, and supply the power again. After check the object is in the maximum measurement range, execute again. After turn off the power, check the connection of sensor head, and supply the power again. If the problem is not resolved after the above items are performed, it is judged that the amplifier unit is defective and needs to be replaced. Check the load of output is specification range. Check the output is contacted other wire or frame. E-17 -17 BD Series ▣ Cautions during Use 1. Follow instructions in 'Cautions during Use'. Otherwise, it may cause unexpected accidents. 2. The power supply should be insulated and limited voltage/current or Class 2, SELV power supply device. 3. Do not install where strong magnetic or electric field exist. Otherwise, the resolution may be adversely affected. 4. Mutual optical interference between laser sensors and photoelectric sensors may result in malfunction. 5. Mutual optical interference between laser sensors may result in malfunction. 6. When connecting DC relay or other inductive load to the output, remove surge by using diode or varistor. 7. Wire as short as possible and keep away from high voltage lines or power lines, to prevent surge and inductive noise. [Amplifier unit] 8. For the optimized performance, it is recommended to measure after 30 minute from supplying power. [Amplifier unit] 9. Since external disturbance light (sunlight, fluorescent lighting, etc.) can cause product malfunction, use the product with a light shield or slit. [Sensor head] 10. When detecting with the maximum sensitivity, an error may occur depending on each characteristic deviation. 11. This unit may be used in the following environments. ①Indoors/Outdoors (in the environment condition rated in 'Specifications') ②Altitude max. 2,000m ③Pollution degree 2 ④Installation category II E-18
BD-100 价格&库存
很抱歉,暂时无法提供与“BD-100”相匹配的价格&库存,您可以联系我们找货
