PRAWT12-2DC
PRAWT12-2DC
    AUTONICS(奥托尼克斯)
    Cylinder,Threaded-M12
    SENSOR PROX INDUCTIVE 2MM CYL
PRAWT12-2DC 数据手册
PRAW Series Cylindrial, Spatter-Resistance, Cable Connector Type Features ● Prevent malfunction due to welding spatter with PTFE coating ● Improved the noise immunity with dedicated IC ● Built-in surge protection circuit ● Built-in output short over current protection circuit ● IP67 protection structure (IEC standard) ● Replaceable for spatter-resistance type limit switches Please read “Safety Considerations” in operation manual before using. The Characteristic of Spatter-Resistance Type The hot arc from arc welding machine is adhesive even with metals or plastics. Therefore, normal proximity sensor might have malfunction even though there are no sensing object if the arcs are put on the sensing surface. The arcs are not adhered on the sensing part of the spatter-resistance type proximity sensor as the part is coated with PTFE against thermal resistance. Also, the protection cover sold optionally has the same function. Specifications ※When the ● DC 2-wire type model name is X, it is non-polarity model. PRAWT12-2 D C PRAWT12-2 D O Model PRAWT12-2 D C-I PRAWT12-2 D O-I Diameter of the sensing side 12mm PRAWT18-5 D O PRAWT18-5 D C PRAWT18-5 D O-I PRAWT18-5 D C-I 18mm PRAWT30-10 D O PRAWT30-10 D C PRAWT30-10 D O-I PRAWT30-10 D C-I 30mm Sensing distance 2mm 5mm 10mm Installation Shield (flush) Hysteresis Max. 10% of sensing distance Standard sensing target 12×12×1mm (iron) 18×18×1mm (iron) 30×30×1mm (iron) Setting distance Power supply (operating voltage) Leakage current 0 to 1.4mm 12-24VDCᜡ (10-30VDCᜡ) Max. 0.6mA 0 to 3.5mm 0 to 7mm Response frequency※1 1.5kHz 500Hz 400Hz Residual voltage※2 Max. 3.5V (non-polarity type is max. 5V) Affection by Temp. Max. ±10% for sensing distance at ambient temperature 20℃ Control output 2 to 100mA Insulation resistance Over 50MΩ (at 500VDC megger) Dielectric strength 1,500VAC 50/60Hz for 1 min (between all terminals and case) Vibration 1mm amplitude at frequency 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Shock 500m/s² (approx. 50G) in each X, Y, Z direction for 3 times Indicator Operation indicator: Red LED Environ- Ambient temperature -25 to 70℃, storage: -30 to 80℃ ment Ambient humidity 35 to 95%RH, storage: 35 to 95%RH Protection circuit Surge protection circuit, output short over current protection circuit Protection structure IP67 (IEC standard) Cable Material Ø4mm, 2-wire, 300mm, M12 connector Ø5mm, 2-wire, 300mm, M12 connector AWG22, Core diameter: 0.8mm, Number of cores: 60, Insulator diameter: Ø1.25mm Case/Nut: PTFE coated brass, Washer: PTFE coated iron, Sensing surface: PTFE, Standard cable (black): Polyvinyl chloride (PVC) Approval Weight※3 Approx. 54g (approx. 42g) Approx. 70g (approx. 58g) Approx. 134g (approx. 122g) ※1: The response frequency is the average value. The standard sensing target is used and the width is set as 2 times of the standard sensing target, 1/2 of the sensing distance for the distance. ※2: Before using non-polarity type, check the condition of connected divice because residual voltage is 5V. ※3: The weight includes packaging. The weight in parenthesis in for unit only. ※For more information about cable and specification, refer to the (I) Connectors/Cable Connectors/Sensor Distribution Boxes/Sockets ※The ' ' of model name is for power type. 'D' is 12-24VDC, 'X' is non-polarity 12-24VDC. ※Environment resistance is rated at no freezing or condensation. F-134 Cylindrial, Spatter-Resistance, Cable Connector Type Dimensions (unit: mm) PRAWT12-2D PRAWT18-5D Ø21 Ø29 300 43 300 47.5 24 32 17 SENSORS CONTROLLERS 29.5 Operation indicator Operation indicator M12 Ø4 4 Ø5 4 M12×1 MOTION DEVICES M12 SOFTWARE M18×1 PRAWT30-10D Ø42 300 58.5 35 38.5 Operation indicator Ø5 (A) Photoelectric Sensors (B) Fiber Optic Sensors M12 M30×1.5 5 (C) LiDAR Control Output Diagram and Load Operation (D) Door/Area Sensors DC 2-wire type Load +V Main circuit Brown (E) Vision Sensors Sensing target Presence None Load Operation Return N.O. N.C. (F) Proximity Sensors (G) Pressure Sensors Operation ON Indicator 0V (red LED) OFF Blue (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets Wiring Diagram DC 2-wire type (standard type) DC 2-wire type (IEC standard type) Normally Open (N.O.) / Normally Closed (N.C.) 2 1 3 4 Brown Load Blue +V 0V ※①, ② are not used terminals. 2 1 3 4 Normally Open (N.O.) Brown Brown Blue Load +V 0V 2 1 3 4 Blue Load Normally Closed (N.C.) Brown +V 0V 2 1 3 4 Blue Load +V 0V ※②,③ of N.O. type and ③,④ of N.C. type are not used terminals. ※The pin arrangement of connector applying IEC standard is being developed. ※Please attach "I" at the end of the name of standard type for purchasing the IEC standard product. E.g.) PRAWT12-2DO-I ※The connector cable for IEC standard is being developed. Please attach "I' at the end of the name of standard type. E.g.) CID2-2-I, CLD2-5-I F-135 PRAW Series PRAWT12-2D Sensing target Detecting Method Sensing distance (X) d One side length Sensing Distance Feature Data by Target Material and Size PRAWT18-5D 2.50 6.00 Iron(SS401) Iron(SS401) Stainless steel 364 (SUS364) 1.50 1.00 Brass(C3601) Aluminum(ALS052) Copper(C1100) 0.50 0.00 4 8 10 12 15 18 20 25 30 35 40 45 50 60 70 75 80 90 100 One side length of sensing target d (mm) PRAWT30-10D 12.00 Iron(SS401) Sensing distance X (mm) 10.00 8.00 Stainless steel 364 (SUS364) 6.00 Brass(C3601) Aluminum(ALS052) Copper(C1100) 4.00 2.00 0.00 F-136 4 8 10 12 15 18 20 25 30 35 40 45 50 60 70 75 80 90 100 One side length of sensing target d (mm) 5.00 Sensing distance X (mm) Sensing distance X (mm) 2.00 4.00 3.00 Stainless steel 364 (SUS364) 2.00 Brass(C3601) Aluminum(ALS052) Copper(C1100) 1.00 0.00 4 8 10 12 15 18 20 25 30 35 40 45 50 60 70 75 80 90 100 One side length of sensing target d (mm) Cylindrial, Spatter-Resistance, Cable Connector Type Sensing Distance Feature Data by Parallel (Left/Right) Movement Detecting Method SENSORS Sensing target Sensing distance (X) Sensing area (Y) CONTROLLERS MOTION DEVICES PRAWT12-2D PRAWT18-5D 2.0 SOFTWARE PRAWT30-10D 5.0 10.0 4.0 8.0 Sensing distance X (mm) Sensing distance X (mm) 1.5 1.3 1.0 0.7 3.0 2.0 Sensing distance X (mm) 1.7 (A) Photoelectric Sensors (B) Fiber Optic Sensors 6.0 (C) LiDAR (D) Door/Area Sensors 4.0 0.4 (E) Vision Sensors 0.1 4.0 3.0 2.0 1.0 0.0 1.0 2.0 3.0 4.0 Left ← Center → Right Sensing area Y (mm) 1.0 10.0 8.0 6.0 4.0 2.0 0.0 2.0 4.0 6.0 8.0 10.0 Left ← Center → Right Sensing area Y (mm) 2.0 10.0 8.0 6.0 4.0 2.0 0.0 2.0 4.0 6.0 8.0 10.0 Left ← Center → Right Sensing area Y (mm) (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets F-137 PRAW Series Proper Usage Load connections Brown Brown + - Load + 24VDC Blue Blue - 24VDC Load When using DC 2-wire type proximity sensor, the load must be connected otherwise internal components may be damaged. The load can be connected to either wire. In case of the load current is small If the load current is under 5mA, please make sure the residual voltage is less than the return voltage of the load by connecting a bleeder resistor in parallel with the load as shown in the diagram. ● DC 2-wire type Brown Vs Vs2 (kΩ) P> (W) I R [I: Action current of load, R: Bleeder resistance, P: Permissible power] R≤ Load Bleeder resistor (R) Blue + - Vs Please make the current on proximity sensor smaller than the return current of load by connecting a bleeder resistor in parallel. ※W value of Bleeder resistor should be bigger for proper heat. Vs Vs2 (kΩ) P> (W) Io-Ioff R Power supply, Io: Min. action current of proximity sensor [ Vs: Ioff: Return current of load, P: Number of Bleeder resistance watt R≤ ] Mutual-interference & Influence by surrounding metals When several proximity sensors are mounted close to one another a malfunction of th may be caused due to mutual interference. Therefore, be sure to provide a minimum distance between the two sensors as below chart indicates. Parallel B A Face to Face When sensors are mounted on metallic panel, you must prevent the sensors from being affected by any metallic object except target. Therefore, be sure to provide a minimum distance as below chart indicates. m Ød n ℓ ℓ ℓ (unit: mm) Item A B ℓ Ød m n F-138 Model PRAWT12-2D PRAWT18-5D PRAWT30-10D 12 24 0 12 6 18 30 36 0 18 15 27 60 60 0 30 30 45
PRAWT12-2DC 价格&库存
很抱歉,暂时无法提供与“PRAWT12-2DC”相匹配的价格&库存,您可以联系我们找货
