8MQ2S1M0D1U0
8MQ2S1M0D1U0
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK PLUG, COMPOSITE SHELL NIC
8MQ2S1M0D1U0 数据手册
A B C D E F G H MASS 9,55 min 8 10,6 g maxi 8 Technical Characteristics Material& finishes • • Shell : Composite nickel plated Locking slide : Composite Electrical 18,65 max 7 25,5 max • • Housing (shell) electrical continuity : < 3m ^ 7 Shielding effectiveness : > 50dB attenuation from 100 to 1 000 MHz Climatic • • Operating temperature range : -55°C to +175°C Salt spray (corrosion) : 500 hrs Mechanical 6 19,30 Max • • • 18,61 max Date code (YY-WW) Compliant EN4165 - BACC65 - ARINC 809 Mating/Unmating: 500 operations 6 Delivered with protective cap Environmental • • RoHS and REACH compliant Fluid resistance : See standard EN 4165-001 (table 40) Locking slide 5 5 Plug part number SOURIAU or EN4165 EN4165 PART NUMBER TABLE 4 EN4165 M Range : Plating : M - Composite nickel plated Shell Type : 6 - Plug Module Quantity : 1 - Mono module Serie : 2 - Serie 2 Polarization : N, A, B, C, D, E, F, G 6 Shell View of "N" polarization Marking on receptacle 1 A N 4 Polarization color (see table) 3 3 8MQ 2 Range : 2 Serie : S 2 - Serie 2 1 M 6 N Polarization 1 - Mono module Plating : M - Composite nickel plated Shell Type : 6 - Plug Polarization : N, A, B, C, D, E, F, G ur N B B table Module Quantity : P/N : SEE TABLE A colour Type of component : S - Shell lo LA RZ Marking on receptacle Co AT IO N SOURIAU PART NUMBER TABLE PO B.2; Validé Shells are compliant for use with modules polarization N, A, B, C, D 27,5 max 21/05/19 ISS DATE Designed by: C D TITLE E F Scale G 3/1 drawing update for EN4165 creation plug Latest modification - by: N.AUFFRET E.FOREST Date:27/09/19 1 H G F E SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) D C FORMAT A2 CUSTOMER DRAWING MOD N $ 2 PLUG 8MQ TYPE 6 BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809 Dimensions in mm General linear Tolerances: www.souriau.com CountryJurisdiction & Control List FR NOT LISTED 24230AB Add marking and codification EN4165 version SOURIAU DRG N° C003-8MQ-A B NPRDS / PROJECT BE133702A This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2S1M0D1U0 价格&库存
很抱歉,暂时无法提供与“8MQ2S1M0D1U0”相匹配的价格&库存,您可以联系我们找货
