8MQ2M0936UCE046
8MQ2M0936UCE046
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, SEALED, WITH FEMA
8MQ2M0936UCE046 数据手册
A B C D E F G H C.2; Validé MASS 18,25 11 Short receptacle # 0,75 3,38 # 0,7 1,69 13,35 Max 3,89 3 - 2 R = Male module delivered with contacts U = Female module delivered with contacts None = Without peripheral sealing E = With peripheral sealing 1 Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H G F E 04/10/18 ISS DATE TITLE S = Delivered with protection cap : : : : C Designed by: N, A, B, C, D = polarization (other dimensions are available for male and female module) 2 P/N : SEE TABLE Layout Dash = No grounding contact contact contact contact ECHELLE 3/2 CountryJurisdiction & Control List FR NOT LISTED M = Module Pin Pin Pin Pin 8,4 3 1- According to EN4165 2- Voltage proof test (Sea level) : - #20 > 1500 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #20 = 67 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap 2 = Serie 2 = = = = Female module ECHELLE 3/2 Tin plated area for version 046/046E/046S None 046 046E 046S 6,75 Technical requirements BASIC SERIE 8MQ 2 M 12-20 R N E S 22,4 Max Male module 4 15,05 Max Female module dimension (g) P/N Marking on this face 3,89 1,69 16,46 Max 5% 3,38 14,2 Max 4 Contact surface with panel # Update of contact position -- Latest modification - by: N.AUFFRET H.SIMIER Date:30/03/17 GAMME 8MQ Scale General linear Tolerances: 3/1 NPRDS / PROJECT BE164803A WWW.SOURIAU.COM A3 CUSTOMER DRAWING MOD N $ MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 12-20 FORMAT D 23536BH C SOURIAU DRG N° C009-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M0936UCE046 价格&库存
很抱歉,暂时无法提供与“8MQ2M0936UCE046”相匹配的价格&库存,您可以联系我们找货
