A
B
C
D
E
F
G
H
C.2; Validé
3,81
Technical requirements
3
1- According to EN4165
2- Voltage proof test (Sea level) :
- #20 > 1500 V r.m.s.
- #22 > 1300 V r.m.s.
3- Insulation resistance > 5000 M ^
4- Climatic sequence : -55°C/+175°C
5- Fluid resistance : See standard
EN 4165-001 (table 40)
6- Contact retention in insert :
- #20 = 67 N
- #22 = 44 N
7- Materials : Thermoplastic and silicone
8- Delivered with protection cap
2
CountryJurisdiction
& Control List
FR
NOT LISTED
2 = Serie 2
Female module dimension
M = Module
R = Male module delivered with contacts
U = Female module delivered with contacts
None = Without peripheral sealing
E = With peripheral sealing
1
Pin
Pin
Pin
Pin
contact
contact
contact
contact
G
F
Gold plated, 0.8µm mini
Tin plated over gold - SnPb
Tin plated over gold - Sn100
Tin plated over gold - SAC305
E
ISS
DATE
Update of contact position
Latest modification - by:
N.AUFFRET
2
H.SIMIER
Date:30/03/17
General linear
Tolerances:
3/1
NPRDS / PROJECT
BE164803A
WWW.SOURIAU.COM
A3
CUSTOMER DRAWING
MOD N $
GAMME 8MQ
FORMAT
D
23536BH
MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 09-36
Scale
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
H
04/10/18
TITLE
S = Delivered with protection cap
None
046
046E
046S
C
Designed by:
N, A, B, C, D = polarization
(other dimensions are available
for male and female module)
3
P/N : SEE TABLE
Layout
Dash = No grounding
22,40 Max
6,6
ECHELLE 3/2
ECHELLE 3/2
Tin plated area for
version 046/046E/046S
BASIC SERIE 8MQ 2 M 09-36 R N E S
5
P/N Marking
on this face
15,05 Max
16,46 Max
(g)
4
14,20 Max
3,81
3,81
#22 :
4
Short receptacle
13,35 Max
# 0,7
5%
Female module
3,81
11
Male module
n 0,8 Max
Contact surface
with panel
# 0,75
#20 :
18,25
n 0,65 Max
MASS
C
SOURIAU DRG N°
C010-8MQ-A
B
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“8MQ2M0816RNS”相匹配的价格&库存,您可以联系我们找货
