n 0,65 Max
4,4
13,35 Max
3,5
3,5
3
Tin plated area for
version 046/046E/046S
2,62
2
1
Gold plated, 0.8µm mini
Tin plated over gold - SnPb
Tin plated over gold - Sn100
Tin plated over gold - SAC305
SOURIAU shall not be liable for any non-conformity or damage due to a usethe
of Products
which does not comply with the Specifications issued by either of the Parties
or by a third party
(professional recommendation, technical notice.)
H
G
F
E
04/10/18
ISS
DATE
TITLE
S = Delivered with protection cap
E
Designed by:
None = Without peripheral sealing
E = With peripheral sealing
contact
contact
contact
contact
9,7
ECHELLE 3/2
2
P/N : SEE TABLE
N, A, B, C, D = polarization
Pin
Pin
Pin
Pin
Female module
CountryJurisdiction
& Control List
FR
NOT LISTED
R = Male module delivered with contacts
U = Female module delivered with contacts
8
1- According to EN4165
2- Voltage proof test (Sea level) :
3
- #22 > 1300 V r.m.s.
- #16 > 1500 V r.m.s.
3- Insulation resistance > 5000 M ^
4- Climatic sequence : -55°C/+175°C
5- Fluid resistance : See standard
EN 4165-001 (table 40)
6- Contact retention in insert :
- #22 = 44 N
- #16 = 110 N
7- Materials : Thermoplastic and silicone
8- Delivered with protection cap
2,62
Layout
Dash = No grounding
None
046
046E
046S
Male module
ECHELLE 3/2
2,62
M = Module
(other dimensions are available
for male and female module)
(g)
4
2 = Serie 2
22,40 Max
5%
Technical requirements
BASIC SERIE 8MQ 2 M 99-01 R N E S
Female module dimension
P/N Marking
on this face
#22 :
4,4
14,20 Max
n 1,25 Max
4
#16 :
15,05 Max
2,62
16,46 Max
A
Short receptacle
B
# 0,7
C
# 0,75
D
11
E
F
G
H
E.2; Validé
18,25
Contact surface
with panel
MASS
Update of contact position
Latest modification - by:
N.AUFFRET
H.SIMIER
Date:11/08/16
BASIC SERIE 8MQ
Scale
General linear
Tolerances:
2/1
NPRDS / PROJECT
BE133701A
WWW.SOURIAU.COM
A3
CUSTOMER DRAWING
MOD N $
MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 99-01
FORMAT
D
23536BH
C
SOURIAU DRG N°
C013-8MQ-A
B
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“8MQ2M9901PNS”相匹配的价格&库存,您可以联系我们找货
