8MQ2M9910RB046
8MQ2M9910RB046
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, SEALED, WITH MALE
8MQ2M9910RB046 数据手册
3,38 1,69 13,35 Max 3,79 3 Tin plated area for version 046/046E/046S 2 1 G F Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 E ISS DATE Update of contact position -- Latest modification - by: N.AUFFRET 2 H.SIMIER Date:30/07/17 General linear Tolerances: 3/1 NPRDS / PROJECT BE164803A WWW.SOURIAU.COM A3 CUSTOMER DRAWING MOD N $ GAMME 8MQ FORMAT D 23536BH MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 99-10 Scale SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H 04/10/18 TITLE S = Delivered with protection cap : : : : C Designed by: None = Without peripheral sealing E = With peripheral sealing (other dimensions are available for male and female module) ECHELLE 3/2 P/N : SEE TABLE N, A, B, C, D = polarization contact contact contact contact 8,55 CountryJurisdiction & Control List FR NOT LISTED R = Male module delivered with contacts U = Female module delivered with contacts Pin Pin Pin Pin Female module 4 - Layout Dash = No grounding = = = = 6,9 1- According to EN4165 2- Voltage proof test (Sea level) : 3 - #16 > 1500 V r.m.s. - #20 > 1500 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #16 = 110 N - #20 = 67 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap M = Module None 046 046E 046S (g) Male module ECHELLE 3/2 2 = Serie 2 22,4 Max 5% Technical requirements BASIC SERIE 8MQ 2 M 99-10 R N E S Female module dimension # P/N Marking on this face 3,79 1,69 14,2 Max n 1,25 Max #16 : n 0,8 Max #20 : 3,38 A MASS 5,07 15,05 Max 16,46 Max B # 0,7 C 4 Short receptacle # 0,75 D 11 E F G H C.2; Validé 18,25 Contact surface with panel 5,07 C SOURIAU DRG N° C014-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M9910RB046 价格&库存
很抱歉,暂时无法提供与“8MQ2M9910RB046”相匹配的价格&库存,您可以联系我们找货
