3,38
1,69
13,35 Max
3,79
3
Tin plated area for
version 046/046E/046S
2
1
G
F
Gold plated, 0.8µm mini
Tin plated over gold - SnPb
Tin plated over gold - Sn100
Tin plated over gold - SAC305
E
ISS
DATE
Update of contact position
Latest modification - by:
N.AUFFRET
2
H.SIMIER
Date:30/07/17
General linear
Tolerances:
3/1
NPRDS / PROJECT
BE164803A
WWW.SOURIAU.COM
A3
CUSTOMER DRAWING
MOD N $
GAMME 8MQ
FORMAT
D
23536BH
MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 99-10
Scale
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
H
04/10/18
TITLE
S = Delivered with protection cap
C
Designed by:
None = Without peripheral sealing
E = With peripheral sealing
(other dimensions are available
for male and female module)
ECHELLE 3/2
P/N : SEE TABLE
N, A, B, C, D = polarization
contact
contact
contact
contact
8,55
CountryJurisdiction
& Control List
FR
NOT LISTED
R = Male module delivered with contacts
U = Female module delivered with contacts
Pin
Pin
Pin
Pin
Female module
4
Layout
Dash = No grounding
6,9
1- According to EN4165
2- Voltage proof test (Sea level) :
3
- #16 > 1500 V r.m.s.
- #20 > 1500 V r.m.s.
3- Insulation resistance > 5000 M ^
4- Climatic sequence : -55°C/+175°C
5- Fluid resistance : See standard
EN 4165-001 (table 40)
6- Contact retention in insert :
- #16 = 110 N
- #20 = 67 N
7- Materials : Thermoplastic and silicone
8- Delivered with protection cap
M = Module
None
046
046E
046S
(g)
Male module
ECHELLE 3/2
2 = Serie 2
22,4 Max
5%
Technical requirements
BASIC SERIE 8MQ 2 M 99-10 R N E S
Female module dimension
P/N Marking
on this face
3,79
1,69
14,2 Max
n 1,25 Max
#16 :
n 0,8 Max
#20 :
3,38
A
MASS
5,07
15,05 Max
16,46 Max
B
# 0,7
C
4
Short receptacle
# 0,75
D
11
E
F
G
H
C.2; Validé
18,25
Contact surface
with panel
5,07
C
SOURIAU DRG N°
C014-8MQ-A
B
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“8MQ2M9910RC”相匹配的价格&库存,您可以联系我们找货
