MATERIAL :
PANEL THICKNESS
Q
6
N
SEALING
CONDITIONS
5
-IP6x : No ingress of dust
-IPx8 1 bar during 1 week: immersion under 10 m of water. (IEC 60529)
-IPx9K : exposure to high pressure water of cleaning equipement(DIN 40050)
0.15
0.1
P
N
10
17.9
16.6
14
22.7
21.3
25.9
24.4
12
Sealing in MATED conditions with COUNTERPART:
1- Contact to be ordered separately for version
UTSX7JC----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
PANEL
THICKNESS
2
3- This part shall be used at the place of the
standard seal to accomodate with different cable
Q
SHELL
O'RING
BACKSHELL
SEAL
BACKSHELL
NUT
BACKSHELL
BODY
Nut
1
10
12
14
0.2
A
0.2
B
27.00
22.15
31.75
27.15
34.90
30.20
H
MAX
C
0.2
D
0.3
E
15.20
18.1
19.15
2.2
22.31
G
MAX
F
HEXAGON backshell nut
P/N : CROSS REF TABLE
A
(Without marking)
SHELL TYPE
G
I1
H
I2
74.5
18.5
1
2.5 / 8
1.5 / 5
28
35.5
11/16 24
77.5
24
2
5 / 12
3 / 9
31.5
39.5
7/8 20
84
26
2.5
7 / 14
5 / 12
35.5
43.5
1"20
F
E
Jam nut
receptacle
7
Normal (no digit)
W,X,Y,Z
JC
SHELL SIZE
10
12
14
TYPE OF
CONTACTS
P: MALE
S: FEMALE
TYPE OF
LAYOUT
Standard layout (No digit)
INSERT
ARRANGEMENT
See NOTA 2
B
16/09/2021
ISS
DATE
TITLE
THREAD
* P/N for example
BACKSHELL
Designed by:
UNEF CLASS
2A
MINI
UTSX 7 JC 14 19 P
BASIC SERIES
B
REDUCING
STANDARD SEAL (NOTA.3)
Tightening
torque (N.m)
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
2
SHELL
SIZE
5
3
CountryJurisdiction& Control List
FR
NOT LISTED
HEXAGON G
(See tightening torque in table)
CAPACITY
H
THREAD
D
3
COMMON DIMENSIONS
FOR ALL VERSION
E
6
UTX_LAYOUT (Standard Version)
4
C
7
NOTA:
SHELL
SIZE
8
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 250 matings and unmatings
Sealing conditions: SEE TABLE
P
PANEL CUT OUT
DEFINITION
F MAX
SHELL : PA UL94 V0, UL746C F1 Black color
BACKSHELLS : PA UL94 V0 F1 Black color
BACKSHELL Seal : CR
INSERT (UTSX7JC-----) : PA UL94 V0, UL746C F1
NUT : Aluminium alloy + Anodic oxidation
O'RING : Nitril
CONTACTS : brass + coated depending on P/N
PERFORMANCE CHARACTERISTICS :
WIRING AREA (between insert and backshell seal)
I2
UTSX7JC----S
7
UTSX7JC----P
I2
A
B
C
D
E
F
G
H
SIDE VIEW FOR EACH VERSION
8
B.2; Validé
PANEL CUT OUT DEFINITION
Scale
3/2
Mass column deleted
25782C
Latest modification - by:
J.GAMBIER
Date:
17/11/2020
Q.LECOMTE
D
C
A2
2
JAM NUT RECEPTACLE WITH BACKSHELL - SIZE 10 12 & 14 - Standard version
CONNECTEUR UTSX
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
FORMAT
CUSTOMER DRAWING
MOD N
3
SOURIAU DRG N°
UTSX-0012A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTSX7JC1492PW”相匹配的价格&库存,您可以联系我们找货
