UTSX7JC103W3S
UTSX7JC103W3S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    JAM NUT RECEPTACLE, WITH CABLE G
UTSX7JC103W3S 数据手册
MATERIAL : - PANEL THICKNESS Q 6 N SEALING CONDITIONS 5 -IP6x : No ingress of dust -IPx8 1 bar during 1 week: immersion under 10 m of water. (IEC 60529) -IPx9K : exposure to high pressure water of cleaning equipement(DIN 40050) 0.15 0.1 P N 10 17.9 16.6 14 22.7 21.3 25.9 24.4 12 Sealing in MATED conditions with COUNTERPART: 1- Contact to be ordered separately for version UTSX7JC----- : refer to corresponding catalogue. 2- Insert arrangement refer to: PANEL THICKNESS 2 3- This part shall be used at the place of the standard seal to accomodate with different cable Q SHELL O'RING BACKSHELL SEAL BACKSHELL NUT BACKSHELL BODY Nut 1 10 12 14 0.2 A 0.2 B 27.00 22.15 31.75 27.15 34.90 30.20 H MAX C 0.2 D 0.3 E 15.20 18.1 19.15 2.2 22.31 G MAX F HEXAGON backshell nut P/N : CROSS REF TABLE A (Without marking) SHELL TYPE G I1 H I2 74.5 18.5 1 2.5 / 8 1.5 / 5 28 35.5 11/16 24 77.5 24 2 5 / 12 3 / 9 31.5 39.5 7/8 20 84 26 2.5 7 / 14 5 / 12 35.5 43.5 1"20 F E Jam nut receptacle 7 Normal (no digit) W,X,Y,Z JC SHELL SIZE 10 12 14 TYPE OF CONTACTS P: MALE S: FEMALE TYPE OF LAYOUT Standard layout (No digit) INSERT ARRANGEMENT See NOTA 2 B 16/09/2021 ISS DATE TITLE THREAD * P/N for example BACKSHELL Designed by: UNEF CLASS 2A MINI UTSX 7 JC 14 19 P BASIC SERIES B REDUCING STANDARD SEAL (NOTA.3) Tightening torque (N.m) 4 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) 2 SHELL SIZE 5 3 CountryJurisdiction& Control List FR NOT LISTED HEXAGON G (See tightening torque in table) CAPACITY H THREAD D 3 COMMON DIMENSIONS FOR ALL VERSION E 6 UTX_LAYOUT (Standard Version) 4 C 7 NOTA: SHELL SIZE 8 Operating temperature: -40 C up to 105C Insulation resistance: 5000 min M Corrosion salt spray: 500 hours Durability: 250 matings and unmatings Sealing conditions: SEE TABLE P PANEL CUT OUT DEFINITION F MAX SHELL : PA UL94 V0, UL746C F1 Black color BACKSHELLS : PA UL94 V0 F1 Black color BACKSHELL Seal : CR INSERT (UTSX7JC-----) : PA UL94 V0, UL746C F1 NUT : Aluminium alloy + Anodic oxidation O'RING : Nitril CONTACTS : brass + coated depending on P/N PERFORMANCE CHARACTERISTICS : WIRING AREA (between insert and backshell seal) I2 UTSX7JC----S 7 UTSX7JC----P WIRING AREA (between insert and backshell seal) I2 A B C D E F G H SIDE VIEW FOR EACH VERSION 8 B.2; Validé PANEL CUT OUT DEFINITION Scale 3/2 Mass column deleted -- 25782C Latest modification - by: J.GAMBIER Date: 17/11/2020 Q.LECOMTE D C A2 2 JAM NUT RECEPTACLE WITH BACKSHELL - SIZE 10 12 & 14 - Standard version CONNECTEUR UTSX Dimensions in mm General linear Tolerances: 0.2 www.souriau.com FORMAT CUSTOMER DRAWING MOD N 3 SOURIAU DRG N° UTSX-0012A-C B NPRDS / PROJECT GBB This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTSX7JC103W3S 价格&库存
很抱歉,暂时无法提供与“UTSX7JC103W3S”相匹配的价格&库存,您可以联系我们找货
