Specification Title:
Clock Oscillator
LVPECL - Complimentary Output
7.0 x 5.0 millimeter Surface Mount
General Product Specification
No.11-3 Jianguo Rd., Tanzi Dist., 42760 Taiwan
All dimensions are millimeters.
CAD:
TCR
Review:
EG
Appr:
JL
Page:
1/4
Date:
August 01,2022
Part Number:
S7A LVPECL Series
Electrical Specifications:
Frequency Range
13.500 ~ 800.000
MHz
Frequency Stability
±25 ~ ±100
ppm
±3
ppm Max.
Aging per Year
Standard
-20 ~ +70
Extended
-40 ~ +85
Operating Temperature Range
°C
-55 ~ +125
Storage Temperature Range
2.5 ± 5%
3.3 ± 5%
VDD
70
70
mA Max.
Logic High (Voh)
1.475
2.275
VDD Min.
Logic Low (Vol)
1.095
1.680
VDD Max.
Supply Voltage
Input Current
Output Voltage
Output Symmetry (Duty Cycle)
45 ~ 55
Output Type
LVPECL
50
Output Load ( Connect to VDD - 2V )
Rise and Fall Time
ohm
13.500 to 99.999MHz
1.0
1.0
100.000 to 160.000MHz
0.5
0.5
160.001 to 800.000MHz
0.5
0.5
ns Max.
Tri-State
Enable-Disable Function
Input Enable Voltage
1.75
2.31
VDD Min.
Input Disable Voltage
0.75
0.99
VDD Max.
Phase Jitter (12 KHz to 20 MHz)
13.500 to 99.999MHz
1
1
2
ps Max. RMS
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change,
output load change, shock, vilbration, and 1st year aging at +25°C.
Ltr
Revisions
RoHS Compliant
Pb - Lead Free
www.aker-usa.com
Date
Appr
Mechanical Outline and Solder Pad Layout:
7.0 ± 0.15
5.0 ± 0.15
#6
#5
Ceramic Base
Metal Lid
#4
AKER
#1
#2
#3
1.4 Max.
5.08
5.08
#2
#3
#6
#5
#4
2.0
1.17
4.20
3.63
#1
1.4
2.54
Pin Connection
PIN No.
Enable/Disable Function
PIN #1
PIN #4 & #5
HIGH or OPEN
Operating
LOW
High Impedance
Connection
#1
Enable/Disable
#2
NC
#3
GND
#4
Output - Q
#5
Output - QN
#6
VDD
1.8
Package is Seam Sealed Ceramic-Metal.
Terminator Pads are Ni/Au.
Dimensions are millimeters.
Page: 2/4
Date : August 01,2022
www.aker-usa.com
P/N: S7A LVPECL Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B
B-B SECTION
7.9
16.0
AKER
AKER
AKER
AKER
A
7.5
Pin #1
A
B
1.7
8.0
2.0
5.4
A-A SECTION
Solder Reflow Characteristics:
Page: 3/4
www.aker-usa.com
How to build a Part Number:
Series
Package
S
7A
Parameter
7.0 x 5.0 mm - 6 Pad
Supply Voltage
33
25
+3.3 VDD ± 5%
+2.5 VDD ± 5%
Temperature Stability
10
05
025
±100 ppm
±50 ppm
±25 ppm
Frequency 13.500~800.000
MHz
Output Load
P
LVPECL
Temperature Range
See Notes
X
-20 ~ +70 °C
-40 ~ +85 °C
Packaging
M
R
250pcs Reel
1000pcs Reel
Part Number Example:
S7A3305-156.250-P-X-R
S7A: 7.0 x 5.0 mm SMD Package - 6 Pad
33: +3.3±5% VDD Supply Voltage
05: ±50 ppm Temperature Stability
156.250 MHz Nominal Frequency
P: LVPECL Output
X: -40 ~ + 85°C Extended Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped in tape only.
4- Specification subject to change without notice.
Page: 4/4
www.aker-usa.com
很抱歉,暂时无法提供与“S7A3303-25.000-P-R”相匹配的价格&库存,您可以联系我们找货
