Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. FIT-221L-1/16
Construction
1) Tubing Type
Heat Shrinkable Tubing
2) Tubing Material
LSZH Polyolefin
3) Minimum Supplied ID(In)
0.063
4) Maximum Recovered ID (In)
0.031
5) Nominal Recovered Wall Thickness(In)
0.014
6) Color(s)
BLACK
Applicable Specifications
1) UL
Standard 224
125°C / 600 VRMS
VW-1
Environmental
1) EU Directive 2011/65/EU(RoHS2), EU Directive 2015/863/EU (RoHS3):
All materials used in the manufacture of this part are in compliance with
European Directive 2011/65/EU, and the amending Directive 2015/863/EU of
4 June 2015 regarding the restriction of use of certain hazardous substances
in electrical and electronic equipment. regarding the restriction of use of
certain hazardous substances in electrical and electronic equipment.
2) REACH Regulation (EC 1907/2006):
This product does not contain Substances of Very High Concern (SVHC)
listed on the European Union's REACH candidate list in excess of 0.1%
mass of the item.
Properties
Physical & Mechanical Properties
1) Temperature Range
-55 to 125°C
2) Shrink Ratio
Approximately 2:1
3) Full Recovery Temperature
110°C
4) Minimum Shrink Temperature
100°C
5) Tensile Strength
1500psi, Min
ASTM D638
6) Elongation
200%, Min
ASTM D638
7) Low Temperature Flex(-30°C)
no cracking
AMS-DTL-23053
8) Heat Resistance(158°C,168hrs)
100% Elongation, Min
ASTM D638
9) Heat Shock(250°C,4hrs)
no cracking
AMS-DTL-23053
10) Secant Modulus
2.5x10 4 psi, Min
ASTM D882
11) Longitudinal Change
+/-5%
AMS-DTL-23053
12) Shelf Life
25 Years @ 18 to 35°C
Electrical Properties
Chemical Properties
1) Water Absorption
0.70%, Max
ASTM D570
2) Copper stability(158°C,168hrs)
UL 224
3) Corrosion(158°C,16hrs)
no corrosion
AMS-DTL-23053
4) Halogen Free
Yes
5) Lead Free
Yes
Other
Packaging
1) 1000 FT
CR19-0.7: 19.75 x 0.75 x 8 Max. 3 pieces/Min length
125 FT.
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication,
information and specifications described herein are subject to errors or omissions and to changes without notice, and
the listing of such information and specifications does not ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties,
whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential,
indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of
such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection
with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical
information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and
subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges
and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no
portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In
the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019
ALPHA WIRE - all rights reserved.
EU/UK/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: FIT-221L-1/16
FIT-221L-1/16, RoHS-Compliant Commencing With 1/27/2014 Production
Note: all colors and put-ups
This document certifies that the Alpha part number cited above is fully compliant with Directive 2011/65/EU of the European
Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in
the manufacture of electrical and electronic equipment.
This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items
(commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to this Directive for the specific
definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that
this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will
be used within EEE that does fit within the Directive's scope. Additionally, Alpha certifies that the listed part number is in
compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. This product is also in compliance with China RoHS 2 per GB/T 26572-2011.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
Bis(2-ethylhexyl) phthalate (DEHP)
Butyl benzyl phthalate (BBP)
Dibutyl phthalate (DBP)
Diisobutyl phthalate (DIBP)
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief
at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any
other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a
warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Authorized Signatory for the Alpha Wire:
Dave Watson, Director of Engineering
Alpha Wire
2200 US Highway 27 South
1/9/2024
Richmond, IN 47374
Tel: 1-908-925-8000
