PPS16 BK080
PPS16 BK080
    ALPHAWIRE(阿尔法电线)
    线缆密封套 聚酰胺(PA),尼龙 PG16 黑色
PPS16 BK080 数据手册
ALPHA WIRE COMPANY CUSTOMER PRODUCT SPECIFICATION Part Numbers: PPS7-PPS16 Spec Number: PPS Page 1 of 1 Pages Issue: Issue Date: Effective Date: A. Technical Details 1) Material a) Body b) Cap c) Seal 2) Color a) Gray, RAL 7001 3) Protection Class a) IP 68 b) IP 66 4) Flammability a) V2 5) Temperature Rating a) Permanent b) Intermittent 6) Thread Type a) PG according to DIN 40430 7) Approvals a) UL b) CSA Size PG 7 Clamping Range Ø min-max mm inch 3,0-6,5 0.118-0.256 Thread Length TL mm inch 8,0 0.315 1 11/01/2017 11/13/2017 PA 6 (Polyamide 6) PA 6 (Polyamide 6) CR (Chloroprene Rubber) 5 Bar, 30 min (According to UL94) -20°C to +100°C -30°C to +150°C UL 514 CSA C22.2 Thread Ø TD mm inch 12,5 0.492 Spanner Width SW CAP SW BODY mm Inch mm Inch 15 0.591 15 0.591 Outer Ø D mm inch 17,2 0.677 Max. Height H mm inch 57,5 2.264 Part Number PPS7 PG 9 4,0-8,0 0.157-0.315 8,0 0.315 15,2 0.598 19 0.748 19 0.748 21,8 0.858 69,4 2.732 PPS9 PG 11 5,0-10,0 0.197-0.394 8,0 0.315 18,6 0.732 22 0.866 22 0.866 25,3 0.996 81,6 3.213 PPS11 PG 13.5 6,0-12,0 0.236-0.473 10,0 0.394 20,4 0.803 24 0.945 24 0.945 27,6 1.087 93,5 3.681 PPS13 PG16 10,0-14,0 0.394-0.551 10,0 0.394 22,5 0.886 27 1.063 27 1.063 31,1 1.224 106,0 4.173 PPS16 B. Packaging Requirements 1) Standard Package 10 glands per package Although Alpha Wire ("Alpha") makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. 711 Lidgerwood Ave Elizabeth, NJ 07207-0711 Toll Free 1-800-52 ALPHA • T: 1-908-925-8000 • F: 908-925-5411 • Email: info@alphawire.com www.alphawire.com
PPS16 BK080 价格&库存
很抱歉,暂时无法提供与“PPS16 BK080”相匹配的价格&库存,您可以联系我们找货
PPS16 BK080
    • 1+1.08000
    库存:2
    PPS16 BK080
    • 10+31.71014
    库存:170
