CBLT-UA-UC-1
CBLT-UA-UC-1
    CUIDEVICES
    CBL 1000MM USB TYPE A TO USB C 5
CBLT-UA-UC-1 数据手册
Additional Resources: Product Page date 08/05/2022 page 1 of 4 MODEL: CBLT-UA-UC-1 | DESCRIPTION: USB CABLE FEATURES • USB 3.2 Gen 1 • type A male to type C male • 1 meter • TPE jacket • halogen free SPECIFICATIONS parameter conditions/description USB standard USB 3.2 Gen 1 min rated voltage typ max 20 units Vdc rated current 3 A conductor resistance 5 Ω insulation resistance at 300 Vdc 10 operating temperature storage temperature flammability rating UL94V-0 RoHS yes cuidevices.com MΩ -20 80 °C -20 80 °C Additional Resources: Product Page CUI DEVICES | MODEL: CBLT-UA-UC-1 | DESCRIPTION: USB CABLE date 08/05/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.5 mm X.XX ±0.3 mm X.XXX ±0.1 mm unless otherwise noted critical dimension: * ITEM DESCRIPTION MATERIAL PLATING/COLOR 1 cable no UL OD: 5.5±0.15 mm TPE black 2 connector 2 USB 3.2 Gen 1 Type A insulator: blue shell: nickel term.: gold flash 3 connector 1 USB 3.2 Gen 1 Type C insulator: black shell: nickel term.: gold flash 4 over mold TPE black cuidevices.com Additional Resources: Product Page CUI DEVICES | MODEL: CBLT-UA-UC-1 | DESCRIPTION: USB CABLE PACKAGING units: mm Carton Size: 546 x 355 x 186 mm Carton QTY: 100 pcs cuidevices.com date 08/05/2022 | page 3 of 4 Additional Resources: Product Page CUI DEVICES | MODEL: CBLT-UA-UC-1 | DESCRIPTION: USB CABLE date 08/05/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 12/11/2018 1.01 brand update 02/17/2020 1.02 modified design, changed factory 01/28/2022 1.03 updated USB standard 05/10/2022 1.04 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CBLT-UA-UC-1 价格&库存
很抱歉,暂时无法提供与“CBLT-UA-UC-1”相匹配的价格&库存,您可以联系我们找货
