Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 6
MODEL: CMM-4737DT-26386-TR | DESCRIPTION: MEMS MICROPHONE
FEATURES
• digital (PDM)
• small package
• reflow solder compatible
• omnidirectional
ELECTRICAL
parameter
conditions/description
directivity
omnidirectional
sensitivity (S)
at 94 dB SPL, 1 kHz
supply voltage (VDD)
min
typ
max
units
-29
-26
-23
dB FS
1.6
2.0
3.6
V
current consumption (IDD)
sensitivity reduction
VDD = 3.6 ~ 1.6 V
frequency (f)
0.86
mA
-0.5
dB FS
100
10,000
58
Hz
signal to noise ratio (S/N)
at 94 dB SPL, 1 kHz (A-weighted)
dBA
total harmonic distortion (THD)
at 94 dB SPL, 1 kHz
0.2
acoustic overload point (AOP)
at 10% THD, 1 kHz
120
dB SPL
output impedance (Zout)
at 1 kHz
power supply rejection (PSR)
100 mVp-p square wave at 217 Hz (A-weighted)
300
-70
Ω
dB FS
DIGITAL INTERFACE
parameter
sleep current (ISLEEP)
FCLOCK < 1 kHz
fall-asleep time
FCLOCK < 1 kHz
wake-up time
FCLOCK ≥ 1 MHz
short circuit current (ISC)
grounded data pin
min
typ
max
25
50
µA
10
ms
1
output load (CLOAD)
data format
units
10
ms
10
mA
100
pF
3.2
MHz
1-Bit PDM
clock frequency (FCLOCK)
1.0
clock duty cycle (FDC)
40
clock rise time (tCR)
clock fall time (tCF)
2.4
60
10
ns
10
ns
logic input/output low (VIOL)
IOUT = 1 mA
-0.30
0.35xVDD
V
logig input/output high (VIOH)
IOUT = 1 mA
0.65xVDD
VDD+0.3
V
delay time for valid data (tDV)
18
60
ns
delay time for high z (tDH)
ns
Notes:
1. All specifications measured at 23±2°C, humidity at 55±20%, VDD = 2.0 V, FCLOCK = 2.4 MHz, unless otherwise noted.
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMM-4737DT-26386-TR | DESCRIPTION: MEMS MICROPHONE
date 08/05/2022 | page 2 of 6
TIMING CHARACTERISTICS
1/FCLOCK
tCF
tCR
VOH
CLOCK
VOL
tDV
tDH
DATA
(SELECT=VDD)
Mic(High)
Data
Mic(High)
Data
tDV
DATA
(SELECT=Gnd)
Mic(Low)
Data
Microphone
Select (L/R)
High Z
tDH
Mic(Low)
Data
High Z
Asserts Data On
Latch Data On
Mic (High)
VDD
rising clock edge
falling clock edge
Mic (Low)
GND
falling clock edge
rising clock edge
RECOMMENDED INTERFACE CIRCUIT
Vdd
Vdd
Vdd
X)
X)
X)
Select
(L/R)
Select
(L/R)
Select
(L/R)
Mic
(High)
Mic
(Low)
Mic
(Low)
Vdd
Vdd
Gnd Data Clock Vdd
Gnd Data Clock Vdd
Codec
Codec
Single MIC
Double MIC
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 6
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
in packaging
RoHS
yes
max
units
-40
typ
105
°C
-40
85
°C
max
units
MECHANICAL
parameter
dimensions
4.72 x 3.76 x 1.25
acoustic port
top
terminals
surface mount
min
typ
mm
weight
0.025
g
MECHANICAL DRAWING
units: mm
tolerance: ±0.1 mm
4
CLOCK
5
DATA
6
VDD
ļ
ĸ
Ļ
Ĺ
ĺ
ļ
ķ
Ļ
ĸ
ĺ
Ĺ
ĸ
Ļ
Ĺ
ĺ
䃅㻜㻚㻥㻝
Recommended Vacuum Nozzle Pickup
Top View
cuidevices.com
ļ
ķ
Recommended PCB Layout
Top View
L/R
GND
2
3
ķ
GND
5
1
䃅㻜㻚㻤㻠
FUNCTION
TERM.
TERMINAL CONNECTIONS
䃅㻜㻚㻥㻝
Product Page
3D Model
FREQUENCY RESPONSE CURVE
cuidevices.com
PCB Footprint
date 08/05/2022 | page 4 of 6
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 5 of 6
SOLDERABILITY
parameter
reflow soldering
see reflow profile
Note:
min
typ
max
units
260
°C
max
units
85
°C
1. Vacuuming over acoustical hole is not allowed.
2. Not suitable for wash process.
3. Not recommended to exceed 5 reflow cycles.
20~40 s
260
Temperature (°C)
3°C/s max ramp up
6°C/s max ramp down
217
60~150 s
200
150
60~180 s
25
480 s max
Time (sec)
PACKAGING
parameter
min
reel storage
at relative humidity
CMM-4737DT-26386-TR 价格&库存
很抱歉,暂时无法提供与“CMM-4737DT-26386-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+8.014971000+0.96950
- 国内价格 香港价格
- 1+15.174531+1.83553
- 10+12.5935110+1.52332
- 25+11.6369225+1.40761
- 50+10.9447750+1.32389
- 100+10.27537100+1.24292
- 250+9.51972250+1.15152
- 500+8.81986500+1.06686
