Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 6
SERIES: CMS-151125-078X | DESCRIPTION: SPEAKER
FEATURES
• micro-speaker
• 8 Ω impedance
• rated 0.7 W
• 5 available termination options
SPECIFICATIONS
parameter
conditions/description
min
input power
max power: as per IEC-268-5, in 1 cc box
impedance
at 2.0 kHz, 2.37 Vrms, in 1 cc box
coil resistance
resonant frequency (Fo)
at 1.0 Vrms in free air, 10 cm
at 2.37 Vrms in 1 cc box, 10 cm
frequency response
at 0.7 W, 10 cm, avg 0.8, 1.0, 1.5, 2.0 kHz, 1 cc box
distortion
at 800~1200 Hz, 2.37 Vrms, 10 cm
at 1,201~5,000 Hz, 2.37 Vrms, 10 cm
buzz, rattle, etc.
must be normal at sine wave, 0.2~2 kHz, 1 cc box
polarity
cone moves forward w/ positive dc current to “+” terminal
dimensions
15 x 11 x 2.5
magnet
Nd-Fe-B
cone material
PEEK
max
units
0.7
1.0
W
6.8
8
9.2
Ω
6.48
7.2
7.92
Ω
560
800
700
1,000
840
1,200
Hz
Hz
100
sound pressure level
88
91
20,000
Hz
94
dB
15
10
2.37
Vrms
mm
weight
1.5
operating temperature
-20
storage temperature
-30
hand soldering
for maximum 3 seconds (N/A for spring contacts)
RoHS
yes
Notes:
typ
g
70
°C
85
°C
380
°C
1. All specifications measured at 15~35°C, humidity at 25~75%, under 86~106 kPa pressure, unless otherwise noted.
PART NUMBER KEY
CMS-151125-078 XX
Base Number
cuidevices.com
Termination Options:
S = spring contacts
SP = solder pads
L100 = wire leads, no connector
L100A = wire leads with Molex housing 51021-0200
L100B = wire leads with JST housing SHR-02V-S-B
Product Page
3D Model
PCB Footprint
CUI DEVICES | SERIES: CMS-151125-078X | DESCRIPTION: SPEAKER
date 08/05/2022 | page 2 of 6
MECHANICAL DRAWINGS
units: mm
tolerance: ±0.2 mm
SPRING CONTACTS
Recommended Pad Layout
SOLDER PADS
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 6
MECHANICAL DRAWINGS (CONTINUED)
units: mm
tolerance: ±0.2 mm
WIRE LEADS, NO CONNECTOR
wire: UL 1571 32 AWG
WIRE LEADS WITH MOLEX CONNECTOR
WIRE LEADS WITH JST CONNECTOR
wire: UL 1571 30 AWG
connector: Molex 51021-0200
mating connector: Molex 53261-0271
connector: JST SHR-02V-S-B
mating connector: JST BM02B-SRSS-TB
cuidevices.com
Product Page
3D Model
PCB Footprint
RESPONSE CURVES
Frequency Response Curve
Test Conditions: 2.37 Vrms / 10 cm
Total Harmonic Distortion Curve
cuidevices.com
date 08/05/2022 | page 4 of 6
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 5 of 6
PACKAGING
units: mm
Tray Size: 290 x 215 mm
Tray QTY: 100 pcs per tray
Carton Size: 470 x 300 x 310 mm
Carton QTY: 5,000 pcs per carton
6
ITEM:
C/NO:
MADE IN CHINA
cuidevices.com
MODEL:
QTY:
N.W:
PCS
Kg
kg
G.W:
LOT NO
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 6 of 6
REVISION HISTORY
rev.
description
date
1.0
initial release
03/23/2018
1.01
updated drawings
06/08/2018
1.02
brand update
01/23/2020
1.03
added Molex and JST connector options, updated packaging
10/27/2020
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMS-151125-078S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 55+7.73825
- 600+7.39970
