CRJ051-1-TH
CRJ051-1-TH
    CUIDEVICES
    模块化连接器 - 插孔 6p6c(RJ11,RJ12,RJ14,RJ25) 90°角(直角) 屏蔽式,EMI指
CRJ051-1-TH 数据手册
Additional Resources: Product Page | PCB Footprint date 08/05/2022 page 1 of 3 MODEL: CRJ051-1-TH | DESCRIPTION: MODULAR JACK FEATURES • 6P6C (RJ12) • shielded • spring tabs SPECIFICATIONS parameter conditions/description min typ rated voltage rated current withstanding voltage max units 150 Vac 1.5 for 1 minute 1,500 contact resistance 40 insulation resistance 500 storage temperature 6.12 kgf 0 70 °C -40 80 °C life 1,000 flammability rating UL94V-0 RoHS yes packaging carton size: 400 x 303 x 258 mm tray QTY: 230 pcs per tray carton QTY: 2,760 pcs per carton mΩ MΩ insertion/withdrawal force operating temperature A Vac cycles SOLDERABILITY parameter conditions/description wave soldering for maximum 5 seconds min cuidevices.com typ max units 240 °C Additional Resources: Product Page | PCB Footprint CUI DEVICES | MODEL: CRJ051-1-TH | DESCRIPTION: MODULAR JACK date 08/05/2022 | page 2 of 3 MECHANICAL DRAWING units: mm tolerance: X ±0.5 mm X.X ±0.38 mm X.XX ±0.25 mm X.XXX ±0.10 mm PCB: ±0.05 mm PCB thickness: 1.6 mm unless otherwise noted ITEM DESCRIPTION MATERIAL PLATING/COLOR 1 insulator PBT (UL94V-0) black 2 contact terminals phosphor bronze contact area: 6 µ” gold over nickel solder area: tin over nickel 3 shield brass nickel alloy Recommended PCB Layout Top View cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | MODEL: CRJ051-1-TH | DESCRIPTION: MODULAR JACK date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 04/16/2021 1.01 logo, datasheet style update 08/05/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CRJ051-1-TH 价格&库存
很抱歉,暂时无法提供与“CRJ051-1-TH”相匹配的价格&库存,您可以联系我们找货
