TE054003-5
TE054003-5
    DBUNLIMITED
    机电元件 蜂鸣器 传感器,外部驱动 3 V 100mA 4kHz 75dB @ 3V,10cm 表面贴装型 焊盘
TE054003-5 数据手册
4 3 2 1 Part Number: DRAWN 2/28/2020 CJ TE054003-5 CHECKED 4/7/2020 P.D. Description: APPROVED Electro-Mechanical Transducer D 4/7/2020 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Side View Bottom View C Recommended Land Pattern C Dummy Pad 4.2 3 - 0.7 5.0 0.8 (-) 3 - 1.2 5.0 1.2 3 - 1.5 (+) 2.5 2 1.2 Top View 2 1.7 2 Max. 5.5 B A B Items Specifications Conditions Min. Sound Pressure Level 78 dB (@ 10cm) Resonant Frequency 4,000 Hz Rated Voltage 3 V Voltage Range 2~5 V Coil Resistance 12 Ω Max. Rated Current 100 mA Storage Temperature -40 ~ +85 °C Operating Temperature -40 ~ +85 °C Connection Method Surface Mount Pads 1) All dimensions are in mm unless otherwise noted Mount Type Surface Mount 2) All tolerances are ± 0.5 mm unless otherwise noted Housing Material LCP Weight 0.3 4 REVISION HISTORY REV DESCRIPTION DATE Released from Engineering 4/7/2020 J.S. Revised SPL 8/13/2021 P.D. 1 APPROVED NOTES 3) All parts meet RoHS g 3 4) Subject to change or redrawn without notice 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
TE054003-5 价格&库存
很抱歉,暂时无法提供与“TE054003-5”相匹配的价格&库存,您可以联系我们找货
