1000-3NF
1000-3NF
    MENDA
    拆焊 织物/棉芯 未稀释
1000-3NF 数据手册
1000 WickGun™ Desoldering Braid Dispenser FEED DIRECTION Loading the WickGun™ Important - With WickGun™ pointing left insert cassette with label facing up so wick will feed from the right (counter clockwise). 1. Grasp cassette and pull out foam plug, then pull out approximately 2 1/4" (57 mm) of wick. 2. Insert wick into guide slot. Rotate drive knob in feed direction while seating cassette. Ensure wick is not pinched between cassette and WickGun™ and that cassette alignment tabs are seated in the alignment slots in the gun. 3. If wick fails to feed, disengage cassette, grasp wick and pull from wick guide slot, do not allow cassette to unwind. Eliminate any kinks and/or frayed wick. Repeat steps 1 – 2. CUTTING BLADE Operating Instructions NOSE CLIP 1. Hold with thumb on drive knob and index finger over the trigger. 2. Rotate drive knob in feed direction exposing 3/4" to 1" (19 to 25 mm) of wick. Do not press on the trigger while dispensing wick. 3. Perform desoldering operation. 4. Squeeze trigger to cut off filled wick. Caution: to prevent jamming, do not retract wick more than 1/2" (12 mm) past cutting blades and never retract solder saturated wick past cutting blades. DRIVE KNOB SCREW LEVER TRIGGER Replacing the Cutter 1. To remove cutter: A. Remove lever by pressing up and sliding forward. B. Slide nose clip up, then out to disengage. C. Slide cutter out through front. 2. To install new Cutter: A. Slide cutter inserting feed tube through slot in back. B. Slide lever into place. Nose clip tabs must be seated in lever locator holes. Compress with appropiate object pushed through small hole in lever to facilitate this step. 3. To maintain good cutting action periodically remove blades and clean with flux solvent. AVOID contact between solvent and plastic parts. STEP B. STEP C. NOSE CLIP CUTTER LEVER LOCATOR HOLES LEVER STEP A. 11520 K-Tel Drive, Minnetonka, Minnesota 55343 Phone: 909-627-2453 | Email: Service@EasyBraidco.com | Web: EasyBraidco.com November 2022 Page 1 of 2 © 2022 DESCO INDUSTRIES INC Employee Owned 1000 WickGun™ Desoldering Braid Dispenser Replacement Cassettes PART NO. DESCRIPTION W4015-1 Cassette, Replacement, #1 Quick Braid Rosin Wick W4015-1LF Cassette, Replacement, #1 Wick, Lead-Free W4015-1NC Cassette, Replacement, #1 One Step No-Clean Wick W4015-1NF Cassette, Replacement, #1 Wick, Sea Braid Unfluxed W4015-2 Cassette, Replacement, #2 Quick Braid Rosin Wick W4015-2LF Cassette, Replacement, #2 Wick, Lead-Free W4015-2NC Cassette, Replacement, #2 One Step No-Clean Wick W4015-2NF Cassette, Replacement, #2 Wick, Sea Braid Unfluxed W4015-3 Cassette, Replacement, #3 Quick Braid Rosin Wick W4015-3LF Cassette, Replacement, #3 Wick, Lead-Free W4015-3NC Cassette, Replacement, #3 One Step No-Clean Wick W4015-3NF Cassette, Replacement, #3 Wick, Sea Braid Unfluxed W4015-4 Cassette, Replacement, #4 Quick Braid Rosin Wick W4015-4LF Cassette, Replacement, #4 Wick, Lead-Free W4015-4NC Cassette, Replacement, #4 One Step No-Clean Wick W4015-4NF Cassette, Replacement, #4 Wick, Sea Braid Unfluxed W4015-5 Cassette, Replacement, #5 Quick Braid Rosin Wick W4015-5LF Cassette, Replacement, #5 Wick, Lead-Free W4015-5NC Cassette, Replacement, #5 One Step No-Clean Wick W4015-5NF Cassette, Replacement, #5 Wick, Sea Braid Unfluxed 11520 K-Tel Drive, Minnetonka, Minnesota 55343 Phone: 909-627-2453 | Email: Service@EasyBraidco.com | Web: EasyBraidco.com November 2022 Page 2 of 2 © 2022 DESCO INDUSTRIES INC Employee Owned
1000-3NF 价格&库存
很抱歉,暂时无法提供与“1000-3NF”相匹配的价格&库存,您可以联系我们找货
