DIB02CB23150MV
DIB02CB23150MV
    CARLOGAVAZZI
    电流检测 AC/DC 115 ~ 230VAC
DIB02CB23150MV 数据手册
Monitoring Relays 1-Phase True RMS AC/DC Over or Under Current Types DIB02, PIB02 DIB02 • TRMS AC/DC over or under current monitoring relays • Current measuring through external shunt or CT • Selection of measuring range by DIP-switches • Measuring ranges from 6 to 150 mV AC/DC and 0.4 to 4 Vp AC (MI or MP range) • Adjustable current on relative scale • Adjustable hysteresis on relative scale • Adjustable delay function (0.1 to 30 s) • Programmable latching or inhibit at set level • Output: 8 A SPDT relay N.D. or N.E. selectable • For mounting on DIN-rail in accordance with DIN/EN 50 022 (DIB02) or plug-in module (PIB02) • 22.5 mm Euronorm housing (DIB02) or 36 mm plug-in module (PIB02) • LED indication for relay, alarm and power supply ON • Galvanically separated power supply PIB02 Product Description Ordering Key DIB02 and PIB02 are precise TRMS AC/DC over or under current (selectable by DIP-switch) monitoring relays. The current is measured through an external shunt. 1-phase and 3-phase current up to 500 AAC can be monitored connecting MI or MP current transformers. Housing Function Type Item number Output Power supply Range Owing to the built-in latch function, the ON-position of the relay output can be maintained. Inhibit function can be used to avoid relay operation when not desired (maintenance, transitions). The LED's indicate the state of the alarm and the output relay. DIB 02 C B23 150mV Type Selection Mounting Output Supply: 24 to 48 VAC/DC Supply: 115/230 VAC DIN-rail Plug-in SPDT SPDT DIB 02 C D48 150MV PIB 02 C D48 150MV DIB 02 C B23 150MV PIB 02 C B23 150MV Input Specifications Input (voltage level) DIB02 PIB02 Measuring ranges Direct Selectable by DIP-switch 6 to 60 mV AC/DC 15 to 150 mV AC/DC Max. voltage for 1 s 0.4 to 4 Vp AC Max. voltage for 1 s MI and MP CT ranges 3-ph.: 1-ph.: MI 5 MP 3005 MI 20 MP 3020 MI 100 MP 3100 MI 500 MP 3500 Terminals Y1, Y2 Terminals 5, 7 Internal resis. Max. volt. 1 kΩ 1 kΩ 2V 2V 15 V 50 V 100 V 50 kΩ AAC rms 0.5 to 5 A 2 to 20 A 10 to 100 A 50 to 500 A Note: MP3... current transformers not suitable for under current measurement due to the output signal of the device (see data sheet) Contact input DIB02 PIB02 Disabled Enabled Latch disable Terminals Z1, Y1 Terminals 8, 9 > 10 kΩ < 500 Ω > 500 ms Max. curr. 20 AAC 50 AAC 250 AAC 750 AAC Note: The input voltage cannot raise over 300 VAC/DC with respect to ground (PIB02 only) Specifications are subject to change without notice (07.02.08) 1 DIB02, PIB02 Output Specifications General Specifications Output Rated insulation voltage Contact ratings (AgSnO2) Resistive loads AC 1 DC 12 Small inductive loads AC 15 DC 13 Mechanical life Electrical life Power ON delay Reaction time SPDT relay 250 VAC µ 8 A @ 250 VAC 5 A @ 24 VDC 2.5 A @ 250 VAC 2.5 A @ 24 VDC ≥ 30 x 106 operations ≥ 105 operations (at 8 A, 250 V, cos ϕ = 1) ≤ 7200 operations/h Operating frequency Dielectric strength Dielectric voltage ≥ 2 kVAC (rms) Rated impulse withstand volt. 4 kV (1.2/50 µs) Supply Specifications Power supply Rated operational voltage through terminals: A1, A2 or A3, A2 (DIB02) 2, 10 or 11, 10 (PIB02) D48: B23: Dielectric voltage Supply to input Supply to output Input to output Rated operational power AC DC Overvoltage cat. III (IEC 60664, IEC 60038) 24 to 48 VAC/DC ± 15% 45 to 65 Hz, insulated 115/230 VAC ± 15% 45 to 65 Hz, insulated DC supply AC supply 2 kV 4 kV 4 kV 4 kV 4 kV 4 kV Alarm ON delay Alarm OFF delay Accuracy Temperature drift Delay ON alarm Repeatability Indication for Power supply ON Alarm ON Output relay ON Environment Degree of protection Pollution degree Operating temperature Storage temperature Housing Dimensions DIB02 PIB02 Weight Screw terminals Tightening torque Approvals CE Marking EMC Immunity Emission 1 s ± 0.5 s or 6 s ± 0.5 s (input signal variation from -20% to +20% or from +20% to -20% of set value) < 100 ms < 100 ms (15 min warm-up time) ± 1000 ppm/°C ± 10% on set value ± 50 ms ± 0.5% on full-scale LED, green LED, red (flashing 2 Hz during delay time) LED, yellow (EN 60529) IP 20 3 (DIB02), 2 (PIB02) -20 to 60°C, R.H. < 95% -30 to 80°C, R.H. < 95% 22.5 x 80 x 99.5 mm 36 x 80 x 94 mm Approx. 150 g Max. 0.5 Nm acc. to IEC 60947 UL, CSA Yes Electromagnetic Compatibillity According to EN 61000-6-2 According to EN 61000-6-3 4 VA 3W Mode of Operation DIB02 and PIB02 monitor both AC and DC over or under current through an external shunt. When connected with MI or MP current transformer (using the 0.4 to 4 Vp range) they can monitor 1-phase or 3-phase AC current up to 500 A. Example 1 (connection between terminals Z1, Y1 or 8, 9 - latching function enabled) The relay operates and latches in operating position when the measured value 2 exceeds (or drops below) the set level for more than the set delay time. Provided that the current has dropped below (or has exceeded) the set point (see hysteresis setting), the relay releases when the interconnection between terminals Z1, Y1 or 8, 9 is interrupted or the power supply is interrupted as well. The red LED flashes until the delay time has expired or the measured value comes back to a non-alarm value (see hysteresis setting). Example 2 (MI CT) (no connection between terminals Z1, Y1 or 8, 9 - latch function disabled) The relay operates when the current flowing in the CT exceeds (or drops below) the set level for more than the set delay time. It releases when the current drops below (or exceeds) the set level (see hysteresis setting) or when power supply is interrupted. Example 3 (MP CT) (no connection between terminals Z1, Y1 or 8, 9 - latch function disabled - over cur- rent measurement) The relay operates when the maximum current flowing in the CT exceeds the set level for more than the set delay time. It releases when the maximum current drops below the set level (see hysteresis setting) or when power supply is interrupted. Note When the inhibit contact is opened, if the input signal is already in alarm position, the delay time needs to elapse before relay activation. Specifications are subject to change without notice (07.02.08) DIB02, PIB02 Function/Range/Level and Time Delay Setting Adjust the measuring range setting the DIP switches 1 and 2 and select the desired function setting the DIP switches 3 to 6 as shown below. To access the DIP switches open the grey plastic cover as shown below. Selection of level and time delay: Upper knob: Setting of hysteresis on relative scale: 0 to 30% on set value. Centre knob: Current level setting on relative scale: 10 to 110% on full scale. Lower knob: Setting of delay on alarm time on absolute scale (0.1 to 30 s). Measuring range ON ON: 6 to 60 mV AC/DC OFF ON: 15 to 150 mV AC/DC ON OFF: 0.4 to 4 Vp Relay working mode ON: Normally De-Energized OFF: Normally Energized Power ON delay ON: 6 s ± 0.5 s OFF: 1 s ± 0.5 s Contact input ON: Latch function enable OFF: Inhibit function enable Monitoring function ON: Over current OFF: Under current Operation Diagrams Over current - N.D. relay Under current - Latch function - N.D. relay Under current - N.D. relay Over current - Inhibit function - N.D. relay Specifications are subject to change without notice (07.02.08) 3 DIB02, PIB02 Wiring Diagrams 24÷48 VAC/DC 230VAC 115VAC 24÷48 VAC/DC 230VAC 115VAC 24÷48 VAC/DC 230VAC 115VAC 24÷48 VAC/DC 230VAC 115VAC 24÷48 VAC/DC 230VAC 115VAC 24÷48 VAC/DC 230VAC 115VAC DIB02 PIB02 Dimensions Plug-in DIN-rail 94 80 63 28.5 4 90 36 63 99.5 83.5 80 22.5 28.5 Specifications are subject to change without notice (07.02.08)
DIB02CB23150MV 价格&库存
很抱歉,暂时无法提供与“DIB02CB23150MV”相匹配的价格&库存,您可以联系我们找货
DIB02CB23150MV
    • 1+1961.16071
