EI1808PPOPL
EI1808PPOPL
    CARLOGAVAZZI
    Cylinder,Threaded-M18
    SENSOR PROX INDUCTIVE 8MM CYLIND
EI1808PPOPL 数据手册
Proximity Sensors Inductive Thermoplastic Polyester Housing Types EI, DC, M12, M18, M30 • Euronorm thermoplastic polyester housing, cylindrical • Diameter: M12, M18, M30 • Flush and non-flush types • Long and short body versions • Sensing distance: 2 to 15 mm • Power supply: 10 to 40 VDC • Output: Transistor NPN/PNP, Normally open or Normaly closed • Protection: Short-circuit, reverse polarity and overload • LED-indication for output ON • 2 m cable or M12 plug Product Description Ordering Key Proximity switch in M12, M18 and M30 polyester housings. Made in accordance with Type Housing diameter (mm) Rated operating dist. (mm) Output type Housing material Body style Plug euronorms EN 50 008 and EN 50 036. EI 1808 PPCPL-1 Type Selection DC Types, Cable and M12 Plug Housing diameter Body style Connection Rated operating dist. (Sn) Ordering no. Transistor NPN Normaly open Ordering no. Transistor PNP Normaly open M12 M12 M12 Long Short Long Cable Cable Cable 2 mm 1) 4 mm 2) 4 mm 2) EI 1202 NPOPL EI 1202 PPOPL EI 1204 PPOPS EI 1204 PPOPL 1) M18 M18 M18 M18 M18 M18 Short Long Short Short Long Long Cable Cable Cable Plug Cable Plug 5 mm 5 mm 1) 8 mm 2) 8 mm 2) 8 mm 2) 8 mm 2) M30 M30 M30 Long Short Long Cable Cable Cable 10 mm 1) 15 mm 2) 15 mm 2) 1) For flush mounting in metal 2) EI 1204 NPOPL EI 1805 NPOPL EI 1808 NPOPS EI 1808 NPOPL EI 3010 NPOPL EI 3015 NPOPS Ordering no. Transistor PNP Normaly closed EI 1805 PPOPS EI 1805 PPOPL EI 1808 PPOPS EI 1808 PPOPS-1 EI 1808 PPOPL EI 1808 PPCPL EI 1808 PPOPL-1 EI 1808 PPCPL-1 EI 3010 PPOPL EI 3010 PPCPL EI 3015 PPOPL For non-flush mounting in metal Specifications Rated operational volt. (Ue) (UB) Ripple Rated operational current (Ie) Continuous No-load supply current (Io) Voltage drop (Ud) Protection Transient voltage Power ON delay 12 to 36 VDC 10 to 40 VDC (ripple incl.) ≤ 10% ≤ 200 mA Output ON: < 6.5 mA Output OFF: < 2.7 mA ≤ 2 VDC at max. load Reverse polarity, short-circuit, transients ≤ 700 V/0.5 J < 10 ms Specifications are subject to change without notice (10.01.14) Frequency of operating cycles (f) EI 1202 EI 1204 EI 1805 EI 1808 EI 3010 EI 3015 Indication for output ON Assured operating dist. (Sa) Repeat accuracy (R) Hysteresis (H) (Differential travel) Effective operating dist. (Sr) Usable operating dist. (S) 800 Hz 500 Hz 500 Hz 400 Hz 300 Hz 100 Hz LED, yellow 0 ≤ Sa ≤ 0.81 Sn ≤ 5% 1 to 15% of sensing distance 0.9 x Sn ≤ Sr ≤ 1.1 x Sn 0.9 x Sr ≤ Su ≤ 1.1 x Sr 1 EI, DC, M12, M18, M30 Specifications (cont.) Weight (cable excluded) Ambient temperature Operating Storage Degree of protection Housing material Body Back Connection Cable EI12 EI 1805 EI 1808 EI 3010 EI 3015 -25° to +70°C (-13° to +158°F) -30° to +80°C (-22° to +176°F) IP 67 (Nema 1, 3, 4, 6, 13) Grey thermoplastic polyester Black polyester Tightening torque EI 12 1.8 Nm EI 18 2.6 Nm EI 30 7.5 Nm UL, CSA Yes Approved acc. to EN 50 080, EN 50 081 2 2 m, 3 x 0.3 mm , grey PVC, oil proof M 12 x 1 CONH1A serie Plug Cables for plug (-1) 10 g 18 g 20 g 50 g 70 g Approvals CE-marking EMC Dimensions Type A B (Ø mm) C (mm) D (mm) E (mm) F (mm) SW (mm) EI 1202 XPXPL EI 1204 XPXPS EI 1204 XPXPL M 12 x 1 x 50 M 12 x 1 x 30 M 12 x 1 x 50 10.7 10.7 10.7 50 34 54 11 11 11 5.0 5.0 5.0 8 8 8 17 17 17 EI 1805 XPXPS EI 1805 XPXPL EI 1808 XPXPS EI 1808 XPXPL EI 1808 XPXPL-1 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 30 M 18 x 1 x 50 M 18 x 1 x 50 16.7 16.7 16.7 16.7 16.7 30 50 38 58 58 11.6 11.6 11.6 11.6 13.1 15.4 15.4 15.4 15.4 11.9 8 8 8 8 8 24 24 24 24 24 M 30 x 1.5 x 50 M 30 x 1.5 x 30 M 30 x 1.5 x 50 28 28 28 50 42 62 13.6 13.6 13.6 15.4 15.4 15.4 10 10 10 36 36 36 EI 3010 XPXPL EI 3015 XPXPS EI 3015 XPXPL D E D C E B B C M 12 x 1 F F SW A SW LED Cable A LED Plug Wiring Diagrams 1 BN + 1 BN + 1 BN + 1 BN + 4 BK BK 2 WH 2 BK WH 4 BK 3 BU - NPN - Normally open 2 3 BU - NPN - Normally closed 3 BU 3 BU PNP - Normally open PNP - Normally closed Specifications are subject to change without notice (10.01.14) EI, DC, M12, M18, M30 Installation Hints To avoid interference from inductive voltage/ current peaks, separate the prox. switch power cables from any other power cables, e.g. motor, contactor or solenoid cables Relief of cable strain Protection of the sensing face Switch mounted on mobile carrier Incorrect Correct The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Power Supplies Power supplies VAC: > SS 110. Power supplies VDC: > SS 130/140. Power supplies with amplifier relays: > SV 190. Specifications are subject to change without notice (10.01.14) 3
EI1808PPOPL 价格&库存
很抱歉,暂时无法提供与“EI1808PPOPL”相匹配的价格&库存,您可以联系我们找货
