AC1422
AS-Interface EtherNet/IP gateway
AS-i Gateway 2Master EIP
Application
Application
EtherNet/IP gateway
Electrical data
Operating voltage
[V]
Current consumption
[mA]
Max. current consumption
from AS-i
[mA]
Number of AS-i masters
18...32 DC; (AUX; AS-i: 21...31,6 V DC)
< 500; (AUX / AS-i 1)
500; (with external supply: 10 mA; AS-i 2: 10 mA)
2
Electrical separation
yes
Outputs
Voltage range DC
[V]
to PELV
Interfaces
Communication interface
Ethernet
Ethernet - EtherNet/IP
Protocol
Usage type
EtherNet/IP
data transmission
Ethernet - Modbus TCP
Transmission rate
Connector type
10 MBaud; 100 MBaud
RJ45
Protocol
Modbus TCP
Usage type
programming
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AC1422-01 — 13.04.2023 —
AC1422
Ethernet - TCP/IP
Transmission rate
10 MBaud; 100 MBaud
Connector type
RJ45
Protocol
TCP/IP
Usage type
programming
Ethernet - UDP/IP
Transmission rate
10 MBaud; 100 MBaud
Connector type
RJ45
Protocol
UDP/IP
Usage type
programming
Operating conditions
Ambient temperature
[°C]
0...60
Storage temperature
[°C]
-20...70
Protection
IP 20
Tests / approvals
MTTF
[years]
40
AS-i classification
AS-i version
3.0
AS-i profile
M4
AS-i certificate
97303
Mechanical data
Weight
[g]
714
Housing
housing for DIN rail mounting
Materials
aluminium powder-coated; steel sheet galvanised; PC
Displays / operating elements
Display
function
1 x LED, red/green
full graphic LCD display
Accessories
Items supplied
Accessories (optional)
terminals
licence: "CODESYS V3", E71400
Remarks
Pack quantity
1 pcs.
AC1422
Electrical connection
terminals: ...2.5 mm²
Connection
很抱歉,暂时无法提供与“AC1422”相匹配的价格&库存,您可以联系我们找货
