DP2122
DP2122
    IFM(易福门)
    SPEED MONITOR IO-LINK - 0 TO 200
DP2122 数据手册
DP2122 Speed monitor IO-Link - 0...2000 Hz Monitoring Display-Speed 1 2 3 push ring LEDs Display Product characteristics Number of inputs and outputs Number of digital inputs: 1; Number of digital outputs: 2 Communication interface IO-Link DP2122_FREQ / CMPT = 1 Measuring range [Hz] 0.1...2000 [U/min] 1...120000 DP2122_REVL / CMPT = 2 Measuring range Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Nominal voltage DC [V] 24 Current consumption Max. current load total [mA] [A] < 380 0.2 Inputs / outputs Number of inputs and outputs Number of digital inputs: 1; Number of digital outputs: 2 Inputs Number of digital inputs Input current limitation 1; (IEC61131-2) [mA] 200 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DP2122-00 — 10.05.2023 — DP2122 Speed monitor IO-Link - 0...2000 Hz Monitoring Display-Speed Outputs Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Short-circuit proof yes Measuring/setting range DP2122_FREQ / CMPT = 1 Measuring range [Hz] 0.1...2000 [U/min] 1...120000 DP2122_REVL / CMPT = 2 Measuring range Accuracy / deviations Hysteresis [%] 0.5...100 Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Measuring Sensor (High resolution, Disable function); Identification and Diagnosis; Switching Signal Channel; Adjustable Switching Signal Channel SIO mode yes Required master port type A Process data binary 1 Min. process cycle time [ms] Supported DeviceIDs 4.3 Type of operation DeviceID DP2122_FREQ / CMPT = 1 1167 DP2122_REVL / CMPT = 2 1294 Operating conditions Ambient temperature [°C] Note on ambient temperature -25...60 2000 m: -25...60 °C 3000 m: -25...53 °C 4000 m: -25...51 °C Storage temperature [°C] -25...60 Max. relative air humidity [%] 90; (linearly decreasing to 50 % (40 °C) non condensing) Max. height above sea level [m] 4000 Protection IP 67 Pollution degree 2 Tests / approvals MTTF [years] 317 Weight [g] 83.8 Weight (without accessories and packaging) [g] Mechanical data Dimensions Materials [mm] 35 63 x 30 x 24 housing: PA ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DP2122-00 — 10.05.2023 — DP2122 Speed monitor IO-Link - 0...2000 Hz Monitoring Display-Speed Displays / operating elements Display operation 1 x LED, green 7-segment LED display, green/red configurable Operating elements 2 push ring Accessories Accessories (optional) mounting clip Remarks Remarks For further information please see the operating instructions. Pack quantity 1 pcs. Electrical connection - plug 1: L+ 2: OUT2 3: L4: OUT1 supply voltage digital output 2 supply voltage IO-Link C/Q Electrical connection - socket 1: L+ 2: 3: L4: 5: Enable input digital input 1 not used ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DP2122-00 — 10.05.2023 —
DP2122 价格&库存
很抱歉,暂时无法提供与“DP2122”相匹配的价格&库存,您可以联系我们找货
