E33208
E33208
    IFM(易福门)
    PROCESS ADAPTER TRI-CLAMP; SENSO
E33208 数据手册
E33208 Process adapter Tri-Clamp ADA IFM-CLAMP ISO2852 1.5" 3A 1 2 3 Aseptoflex Vario sealing area Leakage port Application Design with leakage port Pressure rating [bar] 16 Tests / approvals Pressure Equipment Directive A possible classification to PED depends on the application and has to be carried out by the user / operator. Pressure Equipment Directive EAC The adapter is intended for use in devices, machines and installations that do not fall under the categories of the technical rule TR CU 032/2013. Safety instructions The compatibility between medium and product material has to be checked in all applications. Mechanical data Weight [g] Materials (wetted parts) 101 stainless steel (1.4435 / 316L) ; surface characteristics : Ra
E33208 价格&库存
很抱歉,暂时无法提供与“E33208”相匹配的价格&库存,您可以联系我们找货
推荐型号
