IGS213
IGS213
    IFM(易福门)
    圆柱形,有螺纹-M18
    INDUCTIVE PROXIMITY SENSOR,18MM
IGS213 数据手册
IGS213 Inductive sensor IGK3012-BPKG/US-104 Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing 12 threaded type Dimensions [mm] M18 x 1 / L = 70 Application Special feature Gold-plated contacts; Increased sensing range Application Industrial applications / factory automation Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC < 10 II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 300 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 12 Real sensing range Sr [mm] 12 ± 10 % Operating distance [mm] 0...9.72 Increased sensing range yes Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 [% of Sr] 3...15 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS213-01 — 13.04.2023 — IGS213 Inductive sensor IGK3012-BPKG/US-104 Switch point drift [% of Sr] -10...10 [°C] -25...70 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-5 Surge 0,5 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 1740 Embedded software included yes UL approval Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage UL Approval no. A003 File number UL E174191 Mechanical data Weight [g] 49.7 Housing threaded type Mounting non-flush mountable Dimensions [mm] M18 x 1 / L = 70 Thread designation M18 x 1 Materials housing: brass white bronze coated; sensing face: PBT orange; LED window: PEI; lock nuts: white bronze coated Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS213-01 — 13.04.2023 — IGS213 Inductive sensor IGK3012-BPKG/US-104 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS213-01 — 13.04.2023 —
IGS213 价格&库存
很抱歉,暂时无法提供与“IGS213”相匹配的价格&库存,您可以联系我们找货
