IF0311
Inductive sensor
IFK2004BAROA/SL/LS-100AK
RT
Product characteristics
Output function
Sensing range
normally open
[mm]
Housing
4
threaded type
Dimensions
[mm]
M12 x 1
Application
Special feature
Increased sensing range
Electrical data
Frequency AC
Operating voltage
[Hz]
47...63
[V]
20...140 AC / 10...140 DC
Protection class
I
Reverse polarity protection
no
Outputs
Output function
normally open
Max. voltage drop switching
output DC
[V]
output AC
[V]
5
5
Minimum load current
[mA]
5
Max. leakage current
[mA]
0.8
Permanent current rating of
switching output AC
[mA]
switching output DC
[mA]
Short-time current rating of
switching output
[mA]
Switching frequency AC
[Hz]
25
Switching frequency DC
[Hz]
200
200
200
900; (20 ms / 0,5 Hz)
Short-circuit proof
no
Overload protection
no
Detection zone
Sensing range
[mm]
4
Operating distance
[mm]
0...3.25
yes
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF0311-00 — 13.04.2023 —
IF0311
Inductive sensor
RT
Accuracy / deviations
Correction factor
Hysteresis
steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2
[% of Sr]
3...15
Operating conditions
Ambient temperature
[°C]
-25...70
Protection
IP 67
Tests / approvals
EMC
EN 60947-5-2
EN 55011
MTTF
[years]
UL approval
class B
999
Ta
0...40 °C
Enclosure type
Type 1
power supply
Hazardous voltage
File number UL
E174191
Mechanical data
Weight
[g]
31.2
Housing
threaded type
Mounting
flush mountable
Dimensions
[mm]
M12 x 1
Thread designation
M12 x 1
Materials
brass white bronze coated; PBT
Displays / operating elements
Display
switching status
1 x LED, red
Electrical connection
Required protection
miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting
Accessories
Items supplied
lock nuts: 2
Remarks
Remarks
Pack quantity
Recommendation: Check the safe functioning of the unit after a short circuit.
1 pcs.
Electrical connection - plug
Connector: 1 x 1/2"; coding: C
IF0311
Inductive sensor
RT
Connection
Note miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting
很抱歉,暂时无法提供与“IF0311”相匹配的价格&库存,您可以联系我们找货
