IE5352
IE5352
    IFM(易福门)
    圆柱形,有螺纹-M8
    INDUCTIVE PROXIMITY SENSOR,8MM D
IE5352 数据手册
IE5352 Inductive sensor IEBC005-ASKG/0,3M/US Product characteristics Electrical design PNP/NPN Output function normally open Sensing range [mm] Housing Dimensions 5 threaded type [mm] M8 x 1 / L = 37 Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 10; (only in 3-wire operation) III Reverse polarity protection yes Outputs Electrical design PNP/NPN Output function normally open Max. voltage drop switching output DC [V] 2.8 Minimum load current [mA] 2; (only in 2-wire operation) Max. leakage current [mA] 0.5; (only in 2-wire operation) Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 100 700 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 5 Real sensing range Sr [mm] 5 ± 10 % Operating distance [mm] 0...4.05 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5352-00 — 13.04.2023 — IE5352 Inductive sensor IEBC005-ASKG/0,3M/US Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 Operating conditions Ambient temperature [°C] 0...60 Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 2988 Ta -25...80 °C Enclosure type Type 1 power supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 30.5 Housing threaded type Mounting non-flush mountable Dimensions [mm] M8 x 1 / L = 37 Thread designation M8 x 1 Materials brass white bronze coated; sensing face: LCP Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5352-00 — 13.04.2023 — IE5352 Inductive sensor IEBC005-ASKG/0,3M/US Electrical connection - plug Cable: 0.3 m, PVC; 3 x 0.14 mm² Connector: 1 x M12; coding: A; Locking: rotatable ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5352-00 — 13.04.2023 —
IE5352 价格&库存
很抱歉,暂时无法提供与“IE5352”相匹配的价格&库存,您可以联系我们找货
