IM5132
Inductive sensor
IMC4020BCPKG/K1/US-100-DPA
1
2
LED yellow
LED green
Product characteristics
Electrical design
PNP
Output function
complementary
Sensing range
[mm]
Housing
Dimensions
rectangular
[mm]
40 x 40 x 54
Application
Special feature
Correction factor K = 1; Magnetic-field immune
Max. magnetic field immunity
yes
[mT]
300
Electrical data
Operating voltage
Current consumption
Protection class
Reverse polarity protection
[V]
[mA]
10...36 DC
< 20
II
yes
Outputs
Electrical design
PNP
Output function
complementary
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IM5132-00 — 13.04.2023 —
IM5132
Inductive sensor
Max. voltage drop switching
output DC
[V]
Max. leakage current
[mA]
Permanent current rating of
switching output DC
[mA]
Switching frequency DC
[Hz]
2.5
0.1
200
200
Short-circuit protection
yes
Type of short-circuit
protection
pulsed
Overload protection
yes
Detection zone
Sensing range
[mm]
Real sensing range Sr
[mm]
20 ± 10 %
Operating distance
[mm]
0...16.2
Accuracy / deviations
Correction factor
steel: 1 / stainless steel: 1 / brass: 1 / aluminium: 1 / copper: 1
Hysteresis
[% of Sr]
1...20
Switch point drift
[% of Sr]
-10...10
yes
Operating conditions
Ambient temperature
[°C]
-25...70
Protection
IP 67; IP 69K
Tests / approvals
EMC
MTTF
EN 61000-4-2 ESD
8 kV CD / 6 kV AD
EN 61000-4-3 HF radiated
10 V/m
EN 61000-4-4 Burst
2 kV
EN 61000-4-5 Surge
0,5 kV line to line, Ri: 2 Ohm
EN 61000-4-6 HF conducted
10 V
EN 55011
class B
[years]
UL approval
975
Ta
-25...70 °C
Enclosure type
Type 1
power supply
Class 2
File number UL
E174191
Mechanical data
Weight
[g]
141.5
Housing
rectangular
Sensing face
5 positions selectable
Mounting
Dimensions
flush mountable
[mm]
40 x 40 x 54
Materials
housing: PA; sensing face: PA black; end cap: PA;
clamp: orange; screw: stainless steel (1.4567 / 304Cu)
Displays / operating elements
Display
switching status
1 x LED, yellow
operation
1 x LED, green
IM5132
Inductive sensor
Remarks
Pack quantity
1 pcs.
Electrical connection - plug
Connector: 1 x M12; coding: A; Locking: locking, rotatable, stainless steel (1.4404 / 316L)
Connection
很抱歉,暂时无法提供与“IM5132”相匹配的价格&库存,您可以联系我们找货
