KI5207
KI5207
    IFM(易福门)
    圆柱形,有螺纹-M30
    CAPACITIVE PROXIMITY SENSOR,30MM
KI5207 数据手册
KI5207 Capacitive sensor KI-3015-FPKG/NI RT Product characteristics Electrical design PNP Output function normally open / normally closed; (selectable) Sensing range [mm] 3...15 [mm] M30 x 1.5 / L = 81 Housing threaded type Dimensions Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 13; (24 V) Protection class II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 250 40 Short-circuit proof yes Overload protection yes Detection zone Sensing range [mm] 3...15 Sensing range adjustable yes Factory setting sensing range [mm] 15 Real sensing range Sr [mm] 15 ± 10 % Operating distance [mm] 0...12.1 Accuracy / deviations Correction factor glass: 0.4 / water: 1 / ceramics: 0.2 / PVC: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -15...15 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI5207-00 — 13.04.2023 — KI5207 Capacitive sensor KI-3015-FPKG/NI RT Operating conditions Ambient temperature [°C] -25...70 Protection IP 65 Increased immunity yes; (increased immunity to conducted radio frequency interference) Tests / approvals EMC EN 60947-5-2 MTTF [years] 692 [g] 181 Mechanical data Weight Housing threaded type Mounting non-flush mountable Dimensions [mm] M30 x 1.5 / L = 81 Thread designation M30 x 1.5 Materials PBT Displays / operating elements Display switching status 1 x LED, red Accessories Items supplied lock nuts: 2 screwdriver: 1 Remarks Pack quantity 1 pcs. Electrical connection Cable: 2 m, PVC; 3 x 0.5 mm² Connection BK = BN = BU = Core colours : black brown blue ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — KI5207-00 — 13.04.2023 —
KI5207 价格&库存
很抱歉,暂时无法提供与“KI5207”相匹配的价格&库存,您可以联系我们找货
