LMT104
LMT104
    IFM(易福门)
    POINT LEVEL SENSOR, HIGH FREQUEN
LMT104 数据手册
LMT104 Sensor for point level detection LMDCE-A12E-QSKG-2/US 1 Tightening torque 20...25 Nm Product characteristics Number of inputs and outputs Number of digital outputs: 2 Factory setting hydrous media Process connection threaded connection G 1/2 sealing cone Application Special feature Gold-plated contacts Media Liquids; viscous media; powder Recommended media water; hydrous media; oils; oil-based media; powder Cannot be used for See the operating instructions, chapter "Function and features". Probe length [mm] 153 Tank pressure [bar] -1...40 MAWP (for applications according to CRN) [bar] 40 Oil Medium temperature [°C] Medium temperature short time [°C] -20...100 -20...150; (1 h) Water Medium temperature [°C] Medium temperature short time [°C] -20...100 -20...150; (1 h) Electrical data Operating voltage Current consumption Protection class Reverse polarity protection Measuring principle [V] [mA] 18...30 DC < 50 III yes capacitive ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — LMT104-01 — 13.04.2023 — LMT104 Sensor for point level detection LMDCE-A12E-QSKG-2/US Inputs / outputs Number of inputs and outputs Number of digital outputs: 2 Outputs Total number of outputs 2 Output signal switching signal; IO-Link Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2.5 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Factory setting hydrous media Response times Response time [s] < 0.5 Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Process Data Variable; Device Identification SIO mode yes Required master port type A Process data analogue 1 Process data binary Min. process cycle time 2 [ms] Supported DeviceIDs 2.3 Type of operation DeviceID Default 370 Operating conditions Ambient temperature [°C] -20...85 Note on ambient temperature Medium temperature: < 100 °C -20...60 °C Medium temperature: < 150 °C Storage temperature [°C] -40...85 Protection IP 68; IP 69K Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-4 : closed tanks Shock resistance DIN EN 60068-2-27 50 g (11 ms) Vibration resistance DIN EN 60068-2-6 8 g (10...2000 Hz) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — LMT104-01 — 13.04.2023 — LMT104 Sensor for point level detection LMDCE-A12E-QSKG-2/US MTTF [years] UL approval 222 UL Approval no. H001 Mechanical data Weight [g] Materials 321.5 stainless steel (1.4404 / 316L); stainless steel (1.4571/316Ti ); PEEK; PEI; FKM Materials (wetted parts) stainless steel (1.4404 / 316L); stainless steel (1.4571/316Ti ); PEEK; surface characteristics: Ra < 0,8 / Rz 4; FKM Process connection threaded connection G 1/2 sealing cone Displays / operating elements Display switching status LED, yellow operating status LED, green Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection OUT1: OUT2: BK = BN = BU = WH = switching output IO-Link Teach switching output colours to DIN EN 60947-5-2 Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — LMT104-01 — 13.04.2023 —
LMT104 价格&库存
很抱歉,暂时无法提供与“LMT104”相匹配的价格&库存,您可以联系我们找货
