O2I501
O2I501
    IFM(易福门)
    CODE READER,1D&2D CODES, INFRARE
O2I501 数据手册
O2I501 1D/2D code readers O2IIRDKG/E1/E2/EF/VF/TB/S 1 2 3 lens Illumination unit laser spots Product characteristics Type of light infrared light Image resolution [px] 1280 x 960 Max. reading rate [Hz] 40 [V] 18...30 DC Electrical data Operating voltage Current consumption Protection class Reverse polarity protection Type of light [mA] < 400; (24V DC) III yes infrared light ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O2I501-00 — 13.04.2023 — O2I501 1D/2D code readers O2IIRDKG/E1/E2/EF/VF/TB/S Wave length [nm] 850 Image sensor CMOS image sensor black/white Inputs / outputs Number of inputs and outputs Number of digital inputs: 1; Number of digital outputs: 2 Inputs Trigger external; 24 V PNP/NPN (IEC 61131-2 Typ 3); TCP/IP; EtherNet/IP; internal Number of digital inputs 1 Outputs Total number of outputs 2 Number of digital outputs 2; (configurable) Output function 24 V PNP/NPN Max. voltage drop switching output DC [V] Max. current load per output [mA] 1 100 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Field of view size Operating distance Image resolution [mm] [mm] [px] Lens type Operating distance field of view 85 28 x 21 300 92 x 69 500 152 x 114 1000 302 x 227 > 85 1280 x 960 standard Readable codes Interleaved 2-of-5; Industrial 2-of-5; Code 39; Code 93; Code 128; Pharmacode; Codabar; EAN8; EAN8 Add-On 2; EAN8 Add-On 5; EAN13; EAN13 Add-On 2; EAN13 AddOn 5; UPC-A; UPC-A Add-On 2; UPC-A Add-On 5; UPC-E; UPC-E Add-On 2; UPCE Add-On 5; GS1 DataBar Omnidirectional; GS1 DataBar Truncated; GS1 DataBar Stacked; GS1 DataBar Stacked Omnidirectional; GS1 DataBar Limited; GS1 DataBar Expanded; GS1 DataBar Expanded Stacked; GS1 - 128; MSI Barcode; ECC200; PDF-417; QR; Micro-QR; Aztec Code; GS1 ECC200; GS1 QR Code; GS1 Aztec Code Code quality based on ISO / IEC 15415 ISO / IEC 15416 AIM DPM ISO/IEC TR 29158 SEMI T10 Legible fonts Industrial; Document; OCR-A; OCR-B; Pharma; Semi; Universal; Dot Print Omnidirectional reading Max. inclination to the image plane Max. reading rate yes [°] [Hz] 45 40 Software / programming Parameter setting options teach button; via PC with ifm Vision Assistant ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O2I501-00 — 13.04.2023 — O2I501 1D/2D code readers O2IIRDKG/E1/E2/EF/VF/TB/S Interfaces Communication interface Ethernet Ethernet Number of Ethernet interfaces 1 Transmission standard 10Base-T; 100Base-TX Transmission rate 10 MBit/s; 100 MBit/s Protocol TCP/IP; EtherNet/IP Factory settings IP address: 192.168.0.69 subnet mask: 255.255.255.0 (Class C) gateway IP address: 192.168.0.201 MAC address: see type label Usage type parameter setting; data transmission Operating conditions Ambient temperature [°C] -10...50 Storage temperature [°C] -40...70 Protection IP 65 Tests / approvals EMC Shock resistance Vibration resistance EN 61000-6-4 radiation of interference industrial environments EN IEC 61000-6-2 immunity industrial environments EN 60068-2-27 50 g 11 ms / not repetitive EN 60068-2-27 40 g 6 ms / repetitive EN 60068-2-6 2 g (10 ... 150 Hz) Laser protection class 1 Notes on laser protection Caution: laser light laser class: 1 EN / IEC60825-1:2007 EN / IEC60825-1:2014 Complies with 21 CFR 1040 except for deviations pursuant to Laser Notice No. 50, dated June 2007. Photobiological safety exempt group; (EN 62471) Electrical protection EN 61010-2-201 electrical supply only via PELV circuits Mechanical data Weight [g] Dimensions 599.5 [mm] 45 x 45 x 86 Materials housing: diecast zinc powder-coated; front pane: Gorillaglas; LED window: PC; pushbutton: POM Sealing material FKM Displays / operating elements Display Operating elements function 2 x LED, green function 2 x LED, yellow Teach-Funktion 1 x LED, green Teach-Funktion 1 x LED, yellow 1x Teach-Taste ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O2I501-00 — 13.04.2023 — O2I501 1D/2D code readers O2IIRDKG/E1/E2/EF/VF/TB/S Accessories Accessories (optional) Operating software Mounting accessories Adapter cable protective panes and filter panes Remarks Pack quantity 1 pcs. Electrical connection Electrical connection - Ethernet Connector: 1 x M12; coding: D; Moulded body: stainless steel; Sealing: FKM 1 2 3 4 TxD+ RxD+ TxDRxD- Electrical connection - supply Connector: 1 x M12; coding: A; Moulded body: stainless steel 1 2 3 4 5 U+ trigger input 0V switching output 1 configurable switching output 2 configurable / trigger output with external illumination ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O2I501-00 — 13.04.2023 —
O2I501 价格&库存
很抱歉,暂时无法提供与“O2I501”相匹配的价格&库存,您可以联系我们找货
