O3D300
O3D300
    IFM(易福门)
    3D 检测摄像头 颜色 底座安装
O3D300 数据手册
O3D300 3D sensor O3DIRDKG/E1/GM/T/40 1 2 3 4 lens Illumination unit LED 2-colour yellow/green focus adjustment screw Product characteristics Image resolution 3D Angle of aperture 3D Max. reading rate [px] [°] [Hz] 176 x 132 40 x 30; (nominal value without lens distortion correction) 25 Application Application dimensioning of the object; completeness monitoring; Level monitoring; distance monitoring; volume monitoring Electrical data Operating voltage [V] 20.4...28.8 DC; (EN 61131-2) Current consumption [mA] < 2400; (peak current pulsed; typical value: 420; maximum value: 1600) Power consumption [W] 10; (typical value) Protection class Image sensor Internal lighting III PMD 3D ToF-Chip yes; (infrared: 850 nm invisible radiation LED) Inputs / outputs Number of inputs and outputs Number of digital inputs: 2; Number of digital outputs: 3; Number of analogue outputs: 1 Inputs Trigger 24 V PNP/NPN (IEC 61131-2 Typ 3) Number of digital inputs Input circuit of digital inputs 2 24 V PNP/NPN; (configurable; IEC 61131-2 Typ 3) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O3D300-03 — 23.05.2016 — O3D300 3D sensor O3DIRDKG/E1/GM/T/40 Outputs Total number of outputs 3 Number of digital outputs 3; (configurable) Output function 24 V PNP/NPN; (EN 61131-2) Max. voltage drop switching output DC [V] Max. current load per output [mA] Number of analogue outputs Analogue current output 1 100 1 [mA] 4...20 Max. load [Ω] Analogue voltage output [V] 0...10 Min. load resistance [Ω] 10000 Short-circuit protection 500 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Operating distance [mm] Note on operating distance 300...10000 object size: 200 x 200 mm reflectivity: 18 % Image resolution 3D [px] Angle of aperture 3D [°] Max. reading rate 176 x 132 40 x 30; (nominal value without lens distortion correction) [Hz] 25 [m] < 30 Measuring/setting range Measuring range Software / programming Parameter setting options via PC with ifm Vision Assistant Interfaces Communication interface Ethernet Ethernet Number of Ethernet interfaces 1 Transmission standard 10Base-T; 100Base-TX Transmission rate 10; 100 Protocol TCP/IP; PROFINET IO; EtherNet/IP Factory settings IP address: 192.168.0.69 subnet mask: 255.255.255.0 gateway IP address: 192.168.0.201 Operating conditions Ambient temperature [°C] -10...50 Storage temperature [°C] -40...85 Protection Max. immunity to extraneous light IP 65; IP 67 [klx] 8; (with reduced measuring accuracy and repeatability: < 100) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O3D300-03 — 23.05.2016 — O3D300 3D sensor O3DIRDKG/E1/GM/T/40 Tests / approvals EMC Shock resistance Vibration resistance DIN EN 61000-6-4 radiation of interference / industrial environments DIN EN 61000-6-2 immunity / industrial environments DIN EN 60068-2-27 50 g / (11 ms) not repetitive DIN EN 60068-2-27 40 g / (6 ms) repetitive DIN EN 60068-2-6 2 g / (10...150 Hz) DIN EN 60068-2-64 2.3 g RMS / (10...500 Hz) Photobiological safety exempt group; (DIN EN 62471) Electrical protection MTTF DIN EN 61010-2-201 electrical supply only via PELV circuits [years] 43.08 [g] 803.5 Mechanical data Weight Dimensions [mm] 72 x 67.1 x 82.6 Materials housing: diecast aluminium; front pane: Gorilla Glass; function display: PA Displays / operating elements Display function 2 x LED, green Ethernet operation switching status 2 x LED, yellow OUT 1 OUT 2 Accessories Items supplied Protective covers Remarks Pack quantity 1 pcs. Electrical connection - Ethernet Connector: 1 x M12; coding: D 1 2 3 4 TD + RD + TD RD - ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O3D300-03 — 23.05.2016 — O3D300 3D sensor O3DIRDKG/E1/GM/T/40 Electrical connection - Process connection Connector: 1 x M12; coding: A 1 2 3 4 5 6 7 8 U+ trigger input GND switching output 1 ( digital or analogue ) switching output 3 Ready switching output 2 ( digital ) switching input 1 switching input 2 Other data field of view size with lens distortion correction measuring range / Length [m] Width [m] 0.50 0.26 0.35 1.00 0.52 0.69 2.00 1.04 1.39 3.00 1.56 2.08 4.00 2.08 2.78 5.00 2.61 3.47 distance [m] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O3D300-03 — 23.05.2016 —
O3D300 价格&库存
很抱歉,暂时无法提供与“O3D300”相匹配的价格&库存,您可以联系我们找货
