PI2204
Flush pressure sensor with display
PI-010-REZ01-MFRKG/US/
1
2
3
/P
alphanumeric display 4-digit
status LEDs
programming button
Product characteristics
Number of inputs and outputs
Number of digital outputs: 2; Number of analogue outputs: 1
Measuring range
-1...10 bar
Process connection
-14.5...145 psi
-0.1...1 MPa
Clamp DN40 (1,5") DIN 32676 (ISO 2852)
Application
Special feature
Gold-plated contacts
Application
flush mountable for the food and beverage industry
Media
viscous media and liquids with suspended particles; liquids and gases
Medium temperature
[°C]
-20...200
Min. bursting pressure
100 bar
1450 psi
10 MPa
Pressure rating
50 bar
725 psi
5 Mpa
Type of pressure
relative pressure; vacuum
Electrical data
Min. insulation resistance
[MΩ]
100; (500 V DC)
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PI2204-02 — 13.04.2023 —
PI2204
/P
Protection class
III
Reverse polarity protection
yes
Integrated watchdog
yes
2-wire
Operating voltage
[V]
20...32 DC
Current consumption
[mA]
Power-on delay time
[s]
1
[V]
18...32 DC
3.6...21
3-wire
Operating voltage
Current consumption
[mA]
< 45
Power-on delay time
[s]
0.5
Inputs / outputs
Outputs
Total number of outputs
2
Output signal
switching signal; analogue signal; IO-Link; (configurable)
Electrical design
PNP/NPN
2
Output function
normally open / normally closed; (parameterisable)
Analogue current output
1
[mA]
4...20, invertible; (scalable)
Short-circuit protection
yes
Type of short-circuit
protection
pulsed
Overload protection
yes
2-wire
Max. load
[Ω]
300
3-wire
Max. voltage drop switching
output DC
[V]
Permanent current rating of
switching output DC
[mA]
Switching frequency DC
[Hz]
125
[Ω]
(Ub - 10 V) / 20 mA
Max. load
2
250
Measuring/setting range
Measuring range
-1...10 bar
-14.5...145 psi
-0.1...1 MPa
Set point SP
-0.98...10 bar
-14.2...145 psi
-0.098...1 MPa
Reset point rP
-1...9.98 bar
-14.5...144.7 psi
-0.1...0.998 MPa
Analogue start point
-1...7.5 bar
-14.5...108.7 psi
-0.1...0.75 MPa
Analogue end point
1.5...10 bar
21.8...145 psi
0.15...1 MPa
In steps of
0.01 bar
0.1 psi
0.001 MPa
SP1 = 2.50 bar
rP1 = 2.30 bar
SP2 = 7.50 bar
rP2 = 7.30 bar
ASP = 0.00 bar
AEP = 10.00 bar
Factory setting
PI2204
/P
Accuracy / deviations
Switch point accuracy
[% of the span]
Repeatability
< ± 0,2; (Turn down 1:1)
[% of the span]
< ± 0,1; (with temperature fluctuations < 10 K; Turn down 1:1)
Characteristics deviation
[% of the span]
< ± 0,2; (Turn down 1:1 , linearity, incl. hysteresis and
repeatability , limit value setting to DIN EN IEC 62828-1)
Linearity deviation
< ± 0,15; (Turn down 1:1)
[% of the span]
Hysteresis deviation
[% of the span]
Long-term stability
< ± 0,1; (Turn down 1:1; per year)
[% of the span]
Temperature coefficient zero
point
[% of the span / 10 K]
< ± 0,2; (0...200 °C)
Temperature coefficient span
< ± 0,15; (0...200 °C)
Response times
Damping process value dAP
[s]
Damping for the analogue
output dAA
[s]
0...30
0.01...99.99
2-wire
Step response time analogue
output
[ms]
45
3-wire
Min. response time of
switching output (dAP)
[ms]
output
[ms]
3
7
Interfaces
Communication interface
IO-Link
Transmission type
COM2 (38,4 kBaud)
IO-Link revision
1.0
SDCI standard
IO-Link Communication Specification, Version 1.0, January 2009, Ordner No: 10.002
Profiles
no profile
SIO mode
yes
Required master port type
A
Process data analogue
1
Process data binary
2
Min. process cycle time
[ms]
Supported DeviceIDs
2.3
Type of operation
DeviceID
Default
157
Operating conditions
Ambient temperature
[°C]
Note on ambient temperature
Ambient temperature
-25...80
Medium temperature: ≤ 160 °C
[°C]
-25...65
PI2204
/P
Medium temperature: ≤ 200 °C
Storage temperature
[°C]
-25...100
Protection
IP 67; IP 68; IP 69K
Tests / approvals
EMC
DIN EN 61000-6-2
DIN EN 61000-6-3
Shock resistance
DIN EN 60068-2-27
50 g (11 ms)
Vibration resistance
DIN EN 60068-2-6
20 g (10...2000 Hz)
MTTF
[years]
142
Note on approval
Including free 6-point calibration certificate.
Mechanical data
Weight
[g]
Materials
1053
stainless steel (1.4404 / 316L); stainless steel (1.4435 / 316L); PBT; PEI; PFA
Materials (wetted parts)
Min. pressure cycles
10 million
Process connection
Surface characteristics Ra/Rz
of the wetted parts
< 0.38 / -
Fill fluid for pressure transfer
Diaphragm diameter
NEOBEE (food grade, FDA compliant)
[mm]
34
Displays / operating elements
Display
Display unit
Display unit
LED, green
switching status
LED, yellow
function display
alphanumeric display, 4-digit
measured values
bar; psi; MPa; % of the span
Remarks
Pack quantity
1 pcs.
PI2204
/P
Electrical connection
Connector: 1 x M12; coding: A; Contacts: gold-plated
OUT
OUT1
OUT2
BK =
BN =
BU =
WH =
connection for 2-wire operation :
analogue output
connection for 3-wire operation :
switching output
IO-Link
switching output
analogue output
colours to DIN EN 60947-5-2
Core colours :
black
brown
blue
white
很抱歉,暂时无法提供与“PI2204”相匹配的价格&库存,您可以联系我们找货
