PX3224
Pressure transmitter with ceramic measuring cell
PA-010PRBN14-A-ZVG/US/
1
/V
ventilation
Product characteristics
Number of inputs and outputs
Measuring range
Number of analogue outputs: 1
[psi]
Process connection
0...100
threaded connection 1/4" NPT external thread internal thread:M5
Application
Special feature
Gold-plated contacts
Application
for industrial applications
Media
liquids and gases
Medium temperature
[°C]
-25...90
Min. bursting pressure
[psi]
2175
Pressure rating
[psi]
1087
Type of pressure
relative pressure
Electrical data
Operating voltage
Min. insulation resistance
Protection class
Reverse polarity protection
[V]
[MΩ]
9.6...32 DC
100; (500 V DC)
III
yes
Inputs / outputs
Outputs
Total number of outputs
Output signal
1
analogue signal
1
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — PX3224-00 — 13.04.2023 —
PX3224
/V
Analogue current output
[mA]
Max. load
4...20
[Ω]
720; (Ub = 24 V; (Ub - 9,6 V) / 20 mA)
Overload protection
yes
Measuring/setting range
Measuring range
[psi]
0...100
Accuracy / deviations
Repeatability
[% of the span]
Characteristics deviation
[% of the span]
< 0,15; (with temperature fluctuations < 10 K)
< ± 0,35 (BFSL) / < ± 0,75 (LS); (incl. linearity, zero and span error (limit value setting))
Long-term stability
< ± 0,05; (per 6 months)
[% of the span]
Temperature coefficient zero
point
[% of the span / 10 K]
0,2; (0...80 °C)
Temperature coefficient span
0,3; (0...80 °C)
Response times
Step response time analogue
output
[ms]
3
Operating conditions
Ambient temperature
[°C]
-25...80
Storage temperature
[°C]
-40...100
Protection
IP 65
Tests / approvals
EMC
EN 61000-4-2 ESD
4 kV CD / 8 kV AD
EN 61000-4-3 HF radiated
30 V/m
EN 61000-4-4 Burst
2 kV
EN 61000-4-6 HF conducted
10 V
radiation of interference
according to the automotive directive
2004/104/EC / CISPR 25
immunity
2004/104/EC / ISO 11452-2
HF radiated
100 V/m
pulse resistance
ISO 7637-2 / severity level 3
Shock resistance
DIN IEC 68-2-27
50 g (11 ms)
Vibration resistance
DIN IEC 68-2-6
20 g (10...2000 Hz)
MTTF
[years]
Pressure Equipment Directive
534.69
Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request
Mechanical data
Weight
[g]
Materials
Materials (wetted parts)
212
stainless steel (1.4404 / 316L); FKM; PA; EPDM/X
stainless steel (1.4305 / 303); ceramics; FKM
Min. pressure cycles
100 million
Process connection
Restrictor element integrated
no (can be retrofitted)
PX3224
/V
Remarks
Pack quantity
1 pcs.
Electrical connection
Connector: 1 x M12; coding: A; Contacts: gold-plated
Connection
很抱歉,暂时无法提供与“PX3224”相匹配的价格&库存,您可以联系我们找货
