SBN246
SBN246
    IFM(易福门)
    FLOW METER, 4 DIGIT DISPLAY, 4WI
SBN246 数据手册
SBN246 Flow meter with integrated backflow prevention and display SBN11IF0FRKG Product characteristics Number of inputs and outputs Measuring range Number of digital outputs: 2; Number of analogue outputs: 1 [gph] Process connection 30...1620 threaded connection 1" NPT Application Special feature Gold-plated contacts Application for industrial applications Media Liquids; water; glycol solutions; coolants Note on media oil 1 with viscosity: 10 mm²/s (104 °F) oil 2 with viscosity: 46 mm²/s (104 °F) Medium temperature [°F] 14...212 Pressure rating [bar] 25 Pressure rating [Mpa] 2.5 MAWP (for applications according to CRN) [bar] 25 Electrical data Operating voltage Current consumption [V] [mA] Protection class < 50 III Reverse polarity protection Power-on delay time 18...30 DC; (to SELV/PELV) yes [s] 2 l/min; medium and operating temperature: +71,6 °F ± 4K) ± 1 % MEW ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SBN246-00 — 13.04.2023 — SBN246 Flow meter with integrated backflow prevention and display SBN11IF0FRKG Temperature monitoring Temperature drift 0,9802 °F / K Accuracy [K] 3 K (77 °F; Q > 1 l/min) Response time [s] 0.01 Damping process value dAP [s] 0...5 Damping for the analogue output dAA [s] Response times Flow monitoring 0...5 Temperature monitoring Dynamic response T05 / T09 [s] T09 = 120 (Q > 1 l/min) Software / programming Parameter setting options hysteresis / window; normally open / normally closed; switching logic; current output; medium selection; damping for the switching output / analogue output; display can be rotated and switched off; standard unit of measurement; process value colour Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 CDV Profiles Smart Sensor: Process Data Variable; Device Identification SIO mode yes Required master port type A Process data analogue 2 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 5 Type of operation DeviceID Default 568 Operating conditions Ambient temperature [°F] 32...140 Note on ambient temperature medium temperature < 176 °F medium temperature < 212 °F: 32...104 °F Storage temperature [°F] 5...176 Protection IP 65; IP 67 Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN EN 60068-2-27 20 g (11 ms) Vibration resistance DIN EN 60068-2-6 5 g (10...2000 Hz) MTTF [years] UL approval 145 UL Approval no. Pressure Equipment Directive I006 Sound engineering practice; can be used for group 2 fluids; group 1 fluids on request Mechanical data Weight [g] 1088.9 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SBN246-00 — 13.04.2023 — SBN246 Flow meter with integrated backflow prevention and display SBN11IF0FRKG Materials stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC; brass chemically nickel-plated Materials (wetted parts) stainless steel (316 / 1.4401); stainless steel (1.4404 / 316L); brass (2.0371); brass chemically nickel-plated; PPS; O-ring: FKM Process connection threaded connection 1" NPT Displays / operating elements Display Display unit 3 x LED, green switching status 2 x LED, yellow measured values alphanumeric display, red/green 4-digit programming alphanumeric display, 4-digit Remarks Remarks Recommendation: use a 200-micron filter. All data refer to water (68 °F). MW = measured value MEW = Final value of the measuring range Pack quantity 1 pcs. Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SBN246-00 — 13.04.2023 — SBN246 Flow meter with integrated backflow prevention and display SBN11IF0FRKG Connection OUT1: OUT2: - switching output volumetric flow quantity monitoring switching output Temperature monitoring frequency output volumetric flow quantity monitoring frequency output Temperature monitoring IO-Link switching output volumetric flow quantity monitoring switching output Temperature monitoring analogue output volumetric flow quantity monitoring analogue output Temperature monitoring colours to DIN EN 60947-5-2 Core colours : black brown blue white BK = BN = BU = WH = Diagrams and graphs Pressure loss dP Pressure loss Q volumetric flow quantity ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — SBN246-00 — 13.04.2023 —
SBN246 价格&库存
很抱歉,暂时无法提供与“SBN246”相匹配的价格&库存,您可以联系我们找货
