TA2313
TA2313
    IFM(易福门)
    圆柱形,有螺纹
    TEMPERATURE TRANSMITTER, -58 +30
TA2313 数据手册
TA2313 Temperature transmitter TA-050FLEN12-A-ZVG/US Product characteristics Number of inputs and outputs Measuring range Number of analogue outputs: 1 [°F] Process connection Installation length EL -58...302 threaded connection 1/2" NPT [mm] 50 Application Special feature Gold-plated contacts Measuring element 1 x Pt 1000; (to DIN EN 60751, class A) Media liquids and gases Pressure rating [bar] Note on pressure rating 300 sensor When mounted in adapters the specifications of the adapter data sheet apply. MAWP (for applications according to CRN) [bar] 300 Electrical data Operating voltage Current consumption [V] [mA] Protection class < 50 III Reverse polarity protection Power-on delay time 18...32 DC; ("supply class 2" to cULus) yes [s] 1 Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs 1 Output signal analogue signal; IO-Link; (configurable) Number of analogue outputs Analogue current output Max. load 1 [mA] [Ω] 4...20 250; ((18...19 V); 19...32 V: 300 Ω) Short-circuit protection yes Overload protection yes Measuring/setting range Measuring range [°F] -58...302 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TA2313-00 — 13.04.2023 — TA2313 Temperature transmitter TA-050FLEN12-A-ZVG/US Factory setting 0...300 °F Resolution Resolution of analogue output [K] 0.04 Accuracy / deviations Precision analogue output [K] Temperature coefficient [% of the span / 10 K] ± 0,3 + (± 0,1 % MS) 0,1; (in case of deviation from the reference condition 25 ± 5 °C) Response times Dynamic response T05 / T09 [s] 1/3 Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 67; IP 68; IP 69K Tests / approvals EMC DIN EN 61000-6-2 Shock resistance DIN IEC 68-2-27 50 g (11 ms) DIN IEC 68-2-6 20 g (10...2000 Hz) Vibration resistance MTTF [years] UL approval 572 UL Approval no. K002 Mechanical data Weight Dimensions [g] 132.5 [mm] Ø 18.7 Materials stainless steel (1.4404 / 316L); PEI; FKM Materials (wetted parts) stainless steel (1.4404 / 316L) Process connection threaded connection 1/2" NPT Probe diameter [mm] 6 Installation length EL [mm] 50 Displays / operating elements Display operating status 1 x LED, green Remarks Remarks Pack quantity MS = set measuring span 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TA2313-00 — 13.04.2023 — TA2313 Temperature transmitter TA-050FLEN12-A-ZVG/US Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TA2313-00 — 13.04.2023 —
TA2313 价格&库存
很抱歉,暂时无法提供与“TA2313”相匹配的价格&库存,您可以联系我们找货
