TA2333
Temperature transmitter
TA-100FLEN12-A-ZVG/US
Product characteristics
Number of inputs and outputs
Measuring range
Number of analogue outputs: 1
[°F]
Process connection
Installation length EL
-58...302
threaded connection 1/2" NPT
[mm]
100
Application
Special feature
Gold-plated contacts
Measuring element
1 x Pt 1000; (to DIN EN 60751, class A)
Media
liquids and gases
Pressure rating
[bar]
Note on pressure rating
300
sensor
When mounted in adapters the specifications of the adapter data sheet apply.
MAWP (for applications
according to CRN)
[bar]
300
Electrical data
Operating voltage
Current consumption
[V]
[mA]
Protection class
< 50
III
Reverse polarity protection
Power-on delay time
18...32 DC; ("supply class 2" to cULus)
yes
[s]
1
Inputs / outputs
Outputs
Total number of outputs
1
Output signal
analogue signal; IO-Link; (configurable)
Analogue current output
Max. load
1
[mA]
[Ω]
4...20
250; ((18...19 V); 19...32 V: 300 Ω)
Short-circuit protection
yes
Overload protection
yes
Measuring/setting range
Measuring range
[°F]
-58...302
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TA2333-00 — 13.04.2023 —
TA2333
Factory setting
0...300 °F
Resolution
Resolution of analogue
output
[K]
0.04
Accuracy / deviations
Precision analogue output
[K]
Temperature coefficient
[% of the span / 10 K]
± 0,3 + (± 0,1 % MS)
0,1; (in case of deviation from the reference condition 25 ± 5 °C)
Response times
Dynamic response T05 / T09
[s]
1/3
Interfaces
Communication interface
IO-Link
Transmission type
COM2 (38,4 kBaud)
IO-Link revision
1.1
Operating conditions
Ambient temperature
[°C]
-25...80
Storage temperature
[°C]
-40...100
Protection
IP 67; IP 68; IP 69K
Tests / approvals
EMC
DIN EN 61000-6-2
Shock resistance
DIN IEC 68-2-27
50 g (11 ms)
DIN IEC 68-2-6
20 g (10...2000 Hz)
Vibration resistance
MTTF
[years]
UL approval
572
UL Approval no.
K002
Mechanical data
Weight
Dimensions
[g]
134.5
[mm]
Ø 18.7
Materials
stainless steel (1.4404 / 316L); PEI; FKM
Materials (wetted parts)
Process connection
Probe diameter
[mm]
6
[mm]
100
Displays / operating elements
Display
operating status
1 x LED, green
Remarks
Remarks
Pack quantity
MS = set measuring span
1 pcs.
TA2333
Electrical connection
Connector: 1 x M12; coding: A; Contacts: gold-plated
Connection
很抱歉,暂时无法提供与“TA2333”相匹配的价格&库存,您可以联系我们找货
