TN2333
TN2333
    IFM(易福门)
    圆柱形,有螺纹
    TEMPERATURE SENSOR, 2 X PNP/NPN
TN2333 数据手册
TN2333 Temperature sensor with display TN-100KLBN12-MFRKG/US/ 1 2 3 4 LEDs Display unit / switching status alphanumeric display 4-digit red/green programming buttons upper part of the housing can be rotated 345° Product characteristics Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Measuring range -50...150 °C Process connection Installation length EL -58...302 °F threaded connection 1/2" NPT [mm] 100 Application Special feature Gold-plated contacts Measuring element 1 x Pt 1000; (to DIN EN 60751, class A) Media liquids and gases Pressure rating [bar] 250 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TN2333-00 — 13.04.2023 — TN2333 Temperature sensor with display TN-100KLBN12-MFRKG/US/ Electrical data Operating voltage Current consumption [V] 18...32 DC; ("supply class 2" to cULus) [mA] < 50 Protection class III Reverse polarity protection Power-on delay time yes [s] 1 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of digital outputs: 2; Number of analogue outputs: 1 Outputs Total number of outputs 2 Output signal switching signal; analogue signal; IO-Link; (configurable) Electrical design PNP/NPN Number of digital outputs 2 Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2.5 250 Number of analogue outputs Analogue current output 1 [mA] 4...20 Max. load [Ω] 500 Analogue voltage output [V] 0...10 Min. load resistance [Ω] 2000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range -50...150 °C Factory setting -58...302 °F 0...300 °F Set point SP -49.8...150 °C -57.6...302 °F Reset point rP -50...149.8 °C -58...301.6 °F Analogue start point -50...145 °C -58...293 °F Analogue end point -45...150 °C -49...302 °F In steps of 0.1 °C 0.1 °F Resolution Resolution of switching output [K] Resolution of analogue output [K] Resolution of display [K] 0.1 Switch point accuracy [K] ± 0,3 + (± 0,1 % MS) Precision analogue output [K] ± 0,3 + (± 0,1 % MS) Display accuracy [K] ± 0,3 + (± 0,1 % MS) 0.1 current output: MS / 4096; voltage output: MS / 3561 Accuracy / deviations ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TN2333-00 — 13.04.2023 — TN2333 Temperature sensor with display TN-100KLBN12-MFRKG/US/ Temperature coefficient [% of the span / 10 K] 0,1; (in case of deviation from the reference condition 25 ± 5 °C) Response times Dynamic response T05 / T09 [s] 1 / 3; (to DIN EN 60751) Software / programming Parameter setting options hysteresis / window; normally open / normally closed; switching logic; switch-on/switch-off delay; Damping; Display unit; current/voltage output Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 Operating conditions Ambient temperature [°C] -25...80 Storage temperature [°C] -40...100 Protection IP 67 Tests / approvals EMC DIN EN 61000-6-2 DIN EN 61000-6-3 Shock resistance DIN IEC 68-2-27 50 g (11 ms) Vibration resistance DIN EN 60068-2-6 20 g (10...2000 Hz) MTTF [years] UL approval 207 UL Approval no. K015 Mechanical data Weight [g] 300 Materials stainless steel (1.4404 / 316L); PBT+PC-GF30; PBT-GF20; PC Materials (wetted parts) stainless steel (1.4404 / 316L) Process connection threaded connection 1/2" NPT Installation length EL [mm] 100 Displays / operating elements Display Display unit 2 x LED, green switching status 2 x LED, yellow measured values alphanumeric display, red/green 4-digit Remarks Remarks MS = set measuring span The values for accuracy apply to flowing water. Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TN2333-00 — 13.04.2023 — TN2333 Temperature sensor with display TN-100KLBN12-MFRKG/US/ Electrical connection Connector: 1 x M12; coding: A; Contacts: gold-plated Connection OUT1: OUT2: BK = BN = BU = WH = switching output / IO-Link switching output / analogue output colours to DIN EN 60947-5-2 Core colours : black brown blue white ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TN2333-00 — 13.04.2023 —
TN2333 价格&库存
很抱歉,暂时无法提供与“TN2333”相匹配的价格&库存,您可以联系我们找货
