VSE002
VSE002
    IFM(易福门)
    模块
    振动 传感器 模拟,数字 DIN 轨道 螺丝端子
VSE002 数据手册
VSE002 Diagnostic electronics for vibration sensors DIAGNOSTIC ELECTRONICS 1 2 3 COMBICON connector Ethernet interface DIN rail adapter Product characteristics Frequency range [Hz] Communication interface 0.1...12000 Ethernet Application Design parameter setting via PC software VES004 Application continuous vibration monitoring Electrical data Operating voltage tolerance [%] 20 Operating voltage [V] 24 DC; (when using the IEPE input: 24 V + 20%; IEPE = Integrated Electronics Piezo Electric) Current consumption Protection class [mA] 200; ((24 V DC)) III Inputs / outputs Total number of inputs and outputs Number of inputs and outputs 8; (configurable) Number of analogue inputs: 2; number of dynamic inputs: 4; Number of digital outputs: 2; Number of analogue outputs: 1 Inputs Total number of inputs 6 Number of analogue inputs 2 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSE002-05 — 13.04.2023 — VSE002 Diagnostic electronics for vibration sensors DIAGNOSTIC ELECTRONICS Analogue input (current) [mA] 4...20 Resolution of analogue input 12 Number of dynamic inputs 4 Dynamic input - signal 0...10 mA / IEPE / 4...20 mA Dynamic input - resolution [bit] Dynamic input - frequency range [Hz] 16 0,1...12000 Dynamic input - sampling rate [kSamples] 100 Outputs Total number of outputs 2 Output signal switching signal; analogue signal Electrical design PNP Number of digital outputs 2; (configurable) Output function normally open / normally closed; (parameterisable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 2 100 Number of analogue outputs Analogue current output Max. load 1; (configurable) [mA] 4...20 [Ω] 500 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Frequency range [Hz] 0.1...12000 Interfaces Communication interface Ethernet Transmission rate 10 MBaud; 100 MBaud Protocol TCP/IP Operating conditions Ambient temperature [°C] 0...70 Storage temperature [°C] 0...70 Protection IP 20 Tests / approvals EMC EN IEC 61000-6-2 EN IEC 61000-6-4 MTTF [years] UL approval 101 Ta 70 °C Enclosure type Type 1 power supply Limited Voltage/Current (Marking Class 2) Mechanical data Weight [g] 323.1 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSE002-05 — 13.04.2023 — VSE002 Diagnostic electronics for vibration sensors DIAGNOSTIC ELECTRONICS Housing plastic housing Type of mounting Dimensions rail; (TH35/EN60715) [mm] Materials 100 x 25.4 x 103.4 PA Data memories History memory yes Data memory buffered yes Data memory type ring memory; FIFO Real-time clock yes Memory location internal Memory interval min. 1 min Memory size 881664 data records Accessories Accessories (optional) cross-over Ethernet patch cable for the direct connection to the PC Remarks Pack quantity 1 pcs. Electrical connection COMBICON: ; Maximum cable length: 250 m Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — VSE002-05 — 13.04.2023 —
VSE002 价格&库存
很抱歉,暂时无法提供与“VSE002”相匹配的价格&库存,您可以联系我们找货
