KLDPX-0207-A
KLDPX-0207-A
    KYCON
    套管 - 电源连接器 插孔 2.00mm 内径(0.079"),5.50mm 外径(0.217") 通孔
KLDPX-0207-A 数据手册
IGES 2D Drawing 3D PDF STEP Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDPX-0207-A-1 Part Number Builder R E 140125 LR78160 KLDPX-0207 DC POWER CONNECTORS: KLDPX Series A Diameter Series Panel Mount DC Power Jack Series KLDPX-0207 - Panel Mount DC Power Jack Product Features 2.0mm and 2.5mm Panel Mount Solder Eyelets Built in DC On/Off Switch Portable Electronic Devices CSA/NRTL Certified No. LR78160 UL File No. E140125 Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter Contact Kycon For Other Options KLDPX Series Dimensions in mm Performance Specifications Materials and Finish Plastic Housing : PBT Thermoplastic, UL 94V-0 Rated, Black Color Center Pin: Copper Alloy, Nickel Plated Contact #1: Copper Alloy, Tin Plated Contact #2: Copper Alloy, Tin Plated Contact #3: Copper Alloy, Tin Plated KLDPX-0207-x 14.0 13.0 10.5 A 15.7 Electrical Characteristics A 10.0 Rated Current: 2.5A Rated Voltage: 48V DC Insulation Resistance: 100 Megohms Min. at 500V DC Contact Resistance: 30 Milliohms Max. (Initial) 60 Milliohms Max. (Final) Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute Center Pin "A" Type Ø2.0+0 -0.1 "B" Type Ø2.5+0 -0.1 Ø6.60 1.6 9.6 3 - 4.30±0.30 #3 8.8 3.35 13.5 12.2 #1 (5.40) SECTION A-A 10.90 1.50 5.0 2.00 3 - 3.00 2 - 2.0 4.0 Mechanical Characteristics Insertion Force: 0.3 Kg - 3.0 Kgf Withdrawal Force: 0.3 Kg - 3.0 Kgf Durability: 5000 Mating Cycles Min. Operating Temperature: -25°C to +85°C #2 Schematic 3 2 1 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 1023
KLDPX-0207-A 价格&库存
很抱歉,暂时无法提供与“KLDPX-0207-A”相匹配的价格&库存,您可以联系我们找货
