KUSBVX-SMT-CS-B30TRC
    KYCON
    USB-C(USB TYPE-C) USB 3.2 Gen 2(USB 3.1 Gen 2,Superspeed +(USB 3.1)) 插座 连接器 24 位 表面安装,通孔
KUSBVX-SMT-CS-B30TRC 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBVX-SMT-CS-B30TRC Part Number Builder KUSBVX-SMT UNIVERSAL SERIAL BUS: KUSBVX-SMT Series Series CS B 30 TRC Type Insulator Color Plating Packaging USB Type C Socket, Vertical Mount, SMT Contacts Series KUSBVX-SMT - USB Type C Socket, Vertical Mount, SMT contacts Product Features USB Version 3.1 Gen 2 (10 Gbps) Vertical Mount SMT Contacts Type CS - C Type Performance Specifications Materials and Finish Housing High Temperature Thermoplastic, UL94V-0 Rated Shell: Stainless Steel, Nickel Plated Contact Material Copper Alloy Contact plating 30µ" Gold Plated on Contact Area. Matte Tin Plated on Solder Tails, All over Nickel Underplate Insulator Color Option B - Black W - White Plating Option 30 - 30µ" Gold Plating Packaging TRC - Tape and Reel with Cap Contact Kycon for more options Electrical Characteristics Rated Current 5.0A Inclusive (1.25A Ea.) For Pins A4, A9, B4 and B9 (VBUS) 1.25A Each For Pins, A5 and B5 (CC) 6.25A Inclusive (1.56A Ea.) For Pins A1, A12, B1 and B12 (GND) 0.25A For All Other Pins (RX, TX) Rated Voltage: 30V Insulation Resistance 100 Megohms Min. at 250V DC Contact Resistance 40 milliohms Max. Dielectric Withstanding Voltage 100V AC RMS For 1 Minute KUSBVX-SMT Dimensions in mm Mechanical Characteristics Insertion Force: 5N - 20N Withdrawal Force: 6N - 20N Durability: 10000 Mating Cycles Min. Operating Temperature: -55°C to +85°C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0119
KUSBVX-SMT-CS-B30TRC 价格&库存
很抱歉,暂时无法提供与“KUSBVX-SMT-CS-B30TRC”相匹配的价格&库存,您可以联系我们找货
