PRODUCT
DATASHEET
C16907_ALISE-50-S
ALISE-50-S
~15° spot beam
SPECIFICATION:
Dimensions
Ø 49.9 mm
Height
25 mm
ROHS compliant
yes
MATERIALS:
Component
Type
Material
Colour
ALISE-50-S
Reflector
Aluminium
metal
Finish
Coating
Anodized
ORDERING INFORMATION:
Component
C16907_ALISE-50-S
» Box size: 370 x 320 x 210 mm
Qty in box
750
MOQ
MPQ
100
25
Box weight (kg)
5.8
Last update: 08/11/2023
Subject to change without prior notice
Published: 20/06/2019
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/7
PRODUCT
DATASHEET
C16907_ALISE-50-S
See also our general installation guide: www.ledil.com/installation_guide
2/7
PRODUCT
DATASHEET
C16907_ALISE-50-S
OPTICAL RESULTS (MEASURED):
LED
ZEUBE265 Series
FWHM / FWTM
9.0° / 46.0°
Efficiency
70 %
LEDs/each optic
1
Light colour
UV-C
Required components:
The UVC LED result tolerance is ±10 %
3/7
PRODUCT
DATASHEET
C16907_ALISE-50-S
OPTICAL RESULTS (SIMULATED):
LED
Vero SE 10
FWHM / FWTM
18.0° / 50.0°
Efficiency
87 %
Peak intensity
4.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
CLL02x/CLU02x (LES10)
FWHM / FWTM
22.0° / 60.0°
Efficiency
73 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
C17099_ALISE-50-DL
LED
CMT14xx
FWHM / FWTM
10.0° / 52.0°
Efficiency
90 %
Peak intensity
3.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CoB 1202/1203
FWHM / FWTM
21.0° / 49.0°
Efficiency
97 %
Peak intensity
4.1 cd/lm
LEDs/each optic
1
Light colour
White
4/7
PRODUCT
DATASHEET
C16907_ALISE-50-S
LED
LUXEON CoB 1202s
FWHM / FWTM
19.0° / 42.0°
Efficiency
91 %
Peak intensity
4.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CoB Compact
FWHM / FWTM
19.0° / 43.0°
Efficiency
91 %
Peak intensity
4.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
XFM-5050 4 Die
FWHM / FWTM
16.0° / 32.0°
Efficiency
90 %
LEDs/each optic
1
Light colour
UV-C
LED
WICOP DY9560-27
FWHM / FWTM
21.0° / 44.0°
Efficiency
90 %
LEDs/each optic
24
Light colour
UV-C
5/7
PRODUCT
DATASHEET
C16907_ALISE-50-S
LED
ZEUBE265 Series
FWHM / FWTM
11.0° / 29.0°
Efficiency
90 %
LEDs/each optic
1
Light colour
UV-C
6/7
PRODUCT
DATASHEET
C16907_ALISE-50-S
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
7/7
很抱歉,暂时无法提供与“C16907_ALISE-50-S”相匹配的价格&库存,您可以联系我们找货
