C055047A2
MAGNETICS
Core Marking
MPP
Permeability
(µ)
AL
(nH/T2)
200
90 ± 8%
Dimensions
Part
Number
047A2
Inductance
Grade
X
Coated Limits
Coating
Color
Gray
Packaging
(mm)
(in)
(mm)
(in)
OD (A)
12.70
0.500
13.46
0.530
max
ID (B)
7.62
0.300
6.99
0.275
min
HT (C)
4.75
0.187
5.51
0.217
max
Bulk Pack
4 bags/box
Box Qty= 5000 pcs
Physical Characteristics
DC Bias
min (oersteds)
80%
15.0
1050
Lot
Number
XXXXXX
Uncoated
Electrical Characteristics
Watt Loss
@ 100 kHz, 100mT
max(mW/cm3)
110 Delta Drive
Pittsburgh, PA 15238
NAFTA Sales: (1)800-245-3984
HK Sales : (852)3102-9337
magnetics@spang.com
www.mag-inc.com
50%
28.0
Voltage
Breakdown
wire to wire
min (VAC)
Break
Strength
min (kg)
Window
Area
WA(mm2)
Cross
Section
Ae (mm2)
Path
Length
Le (mm)
Volume
Ve (mm3)
Weight
(g)
1250
15.0
38.3
10.9
31.2
340
3.1930
Winding Information
Winding Length Per Turn
Winding
Factor
(mm)
Winding
Factor
(mm)
0%
20%
25%
30%
35%
17.5
19.3
19.8
20.1
20.7
40%
45%
50%
60%
70%
21.1
21.7
22.1
23.2
24.5
Temperature Rating
Wound Coil Dimensions (mm)
OD
40% Winding Factor
HT
Max OD
Completely Full Window
Max HT
14.6
7.66
18.2
11.5
Curie Temp: 460 ˚C
Coating Temp (Continuous up to):
200 ˚C
Notes:
Surface Area (mm²)
Unwound Core
40% Winding Factor
560
800
Typical DC Bias Performance
100
90
80
80%
AL (nH/T2)
70
60
50%
50
40
30
60
80
100
120
A·T
Revision 10/5/2021
很抱歉,暂时无法提供与“C055047A2”相匹配的价格&库存,您可以联系我们找货
