C055090A2
C055090A2
    MAGNETICS(美磁)
    有涂层 MPP 铁氧体磁芯磁环 型 长度 宽 1.875"(47.63mm) 直径 0.635"(16.13mm) 高
C055090A2 数据手册
C055090A2 MAGNETICS Core Marking MPP Permeability (µ) AL (nH/T2) 60 86 ± 8% Inductance Grade X Coated Limits Coating Color Gray Packaging (in) (mm) (in) OD (A) 46.74 1.840 47.63 1.875 max ID (B) 28.70 1.130 27.89 1.098 min HT (C) 15.24 0.600 16.13 0.635 max Cardboard cut-outs Box Qty= 120 pcs Physical Characteristics DC Bias min (oersteds) 80% 50 Part Number 55090A2 (mm) Electrical Characteristics 700 Lot Number XXXXXX Uncoated Dimensions Watt Loss @ 100 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 3000 99.0 610 134 116 15,600 120 50% 94 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 52.0 59.1 61.0 62.2 64.5 40% 45% 50% 60% 70% 66.4 68.2 70.4 74.7 79.5 Temperature Rating Curie Temp: 460 ˚C Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT 52.0 24.9 66.3 39.8 Coating Temp (Continuous up to): 200 ˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 6,100 9,800 Typical DC Bias Performance 90 80 80% AL (nH/T2) 70 60 50% 50 40 30 20 10 0 0 200 400 600 800 1000 1200 A·T Revision 9/30/2021
C055090A2 价格&库存
很抱歉,暂时无法提供与“C055090A2”相匹配的价格&库存,您可以联系我们找货
