C055120A2
C055120A2
    MAGNETICS(美磁)
    有涂层 MPP 铁氧体磁芯磁环 型 长度 宽 0.653"(16.59mm) 直径 0.250"(6.35mm) 高
C055120A2 数据手册
C055120A2 MAGNETICS AL (nH/T2) 125 72 ± 8% Part Number 55120A2 Inductance Grade X Coated Limits Coating Color Gray Packaging (mm) (in) (mm) (in) OD (A) 16.59 0.653 17.27 0.680 max ID (B) 10.16 0.400 9.53 0.375 min HT (C) 6.35 0.250 7.11 0.280 max Bulk Pack 4 bags/box Box Qty= 2000 pcs Physical Characteristics DC Bias min (oersteds) 80% 25.0 Lot Number XXXXXX Uncoated Electrical Characteristics 850 Core Marking MPP Permeability (µ) Dimensions Watt Loss @ 100 kHz, 100mT max(mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 48.5 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 1250 23.0 71.2 19.2 41.2 791 6.8000 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 22.0 24.4 25.0 25.6 26.2 40% 45% 50% 60% 70% 26.8 27.6 28.3 29.7 31.4 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 460 ˚C 18.8 10.1 23.7 15.2 Coating Temp (Continuous up to): 200 ˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 920 1,300 Typical DC Bias Performance 80 70 80% AL (nH/T2) 60 50 50% 40 30 20 10 0 0 25 50 75 100 125 150 175 200 225 250 A·T Revision 9/30/2021
C055120A2 价格&库存
很抱歉,暂时无法提供与“C055120A2”相匹配的价格&库存,您可以联系我们找货
