C058059A2
C058059A2
    MAGNETICS(美磁)
    有涂层 MPP 铁氧体磁芯磁环 型 长度 宽 0.930"(23.62mm) 直径 0.330"(8.38mm) 高
C058059A2 数据手册
110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com C058059A2 High Flux Permeability (µ) 60 AL (nH/T2) 43 ± 8% Dimensions max (mW/cm3) Part Number 58059A2 Inductance Grade X Coated Limits (mm) (in) (mm) (in) 22.86 0.900 23.62 0.930 max ID (B) HT (C) 13.97 7.62 0.550 0.300 13.34 8.38 0.525 0.330 min max 50% 170 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area Wa(mm2) Cross Section Ae (mm2) 2000 39.0 140 31.7 Winding Length Per Turn (mm) Winding Factor Bulk Pack 4 bags/box Box Qty= 1000 pcs Path Est. Volume Ve Length Weight (mm3) Le (mm) (g) 56.7 (mm) 0% 27.0 40% 33.9 30.5 45% 35.0 25% 31.3 50% 35.9 30% 32.0 33.1 60% 70% 38.0 40.4 1,800 14.3 Temperature Rating Wound Coil Dimensions (mm) 20% 35% Khaki Packaging OD (A) Winding Information Winding Factor Coating Color Physical Characteristics DC Bias min (oersteds) 80% 90 900 Lot Number XXXXXX Uncoated Electrical Characeristics Watt Loss @ 100kHz, 100mT Core Marking 40% Winding Factor Completely Full Window OD HT 26.4 12.6 Max OD 27.8 Max HT 18.2 Curie Temp: 500°C Coating Temp (Continuous up to): 200°C Notes: Surface Area (mm2) Unwound Core 40% Winding Factor 1,600 2,400 Typical DC Bias Performance 45 80% 40 AL (nH/T2) 35 50% 30 25 20 15 10 5 0 0 200 400 600 800 1000 A·T Revision 6/15/2022 1200
C058059A2 价格&库存
很抱歉,暂时无法提供与“C058059A2”相匹配的价格&库存,您可以联系我们找货
