C058121A2
C058121A2
    MAGNETICS(美磁)
    有涂层 高通量 铁氧体磁芯磁环 型 长度 宽 0.680"(17.27mm) 直径 0.280"(7.11mm) 高
C058121A2 数据手册
C058121A2 MAGNETICS AL (nH/T2) 60 35 ± 8% Part Number 58121A2 Inductance Grade X Coated Limits Coating Color Khaki Packaging (mm) (in) (mm) (in) OD (A) 16.59 0.653 17.27 0.680 max ID (B) 10.16 0.400 9.53 0.375 min HT (C) 6.35 0.250 7.11 0.280 max Bulk Pack 4 bags/box Box Qty= 2000 pcs Physical Characteristics DC Bias min (oersteds) 80% 90.0 Lot Number XXXXXX Uncoated Electrical Characteristics 900 Core Marking High Flux Permeability (µ) Dimensions Watt Loss @ 100 kHz, 100mT max (mW/cm3) 110 Delta Drive Pittsburgh, PA 15238 NAFTA Sales: (1)800-245-3984 HK Sales : (852)3102-9337 magnetics@spang.com www.mag-inc.com 50% 170 Voltage Breakdown wire to wire min (VAC) Break Strength min (kg) Window Area WA(mm2) Cross Section Ae (mm2) Path Length Le (mm) Volume Ve (mm3) Weight (g) 1250 23.0 71.2 19.2 41.2 791 5.9220 Winding Information Winding Length Per Turn Winding Factor (mm) Winding Factor (mm) 0% 20% 25% 30% 35% 22.0 24.4 25.0 25.6 26.2 40% 45% 50% 60% 70% 26.8 27.6 28.3 29.7 31.4 Temperature Rating Wound Coil Dimensions (mm) OD 40% Winding Factor HT Max OD Completely Full Window Max HT Curie Temp: 500˚C 18.8 10.1 23.7 15.2 Coating Temp (Continuous up to): 200˚C Notes: Surface Area (mm²) Unwound Core 40% Winding Factor 920 1,300 Typical DC Bias Performance 40.0 35.0 80% AL (nH/T2) 30.0 25.0 50% 20.0 15.0 10.0 5.0 0.0 0 100 200 300 400 500 600 700 800 A·T Revision 9/30/2021
C058121A2 价格&库存
很抱歉,暂时无法提供与“C058121A2”相匹配的价格&库存,您可以联系我们找货
